Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 06-13-2011, 09:48 AM
strap21061 strap21061 is offline
Overheats only when going uphills!
99 expedition. While climbing steep hills, the vehicle runs hot and the antifreeze boils over out the expansion tank bottle from the cap. Any ideas as to what my cause this?
Thanks
Old 06-14-2011, 08:25 PM
Schaff68 Schaff68 is offline
Re: Overheats only when going uphills!
water pump impellar may be missing acouple blades or your radiator is plugged up enough that the hill climbing is making it get to hot. try flushing the system, put in new antifreeze and a small bottle of water wetter.
Old 06-15-2011, 05:56 AM
Thanks for the help. I'll try it tonight.
Old 06-15-2011, 10:34 AM
danielsatur danielsatur is offline
1) Are you towing anything?
2) Is your electric coolant fans working proper?
Old 06-17-2011, 12:17 PM
Not towing anything and it's a clutch fan.
Old 06-17-2011, 07:35 PM
I had a thermo/mech fan clutch go bad!
Over 65MPH it would overheat, I replaced it with a new mechanical fan clutch. ''ok''
1) Clean road litter like bugs, leaves, and other derbis in front of the air cond condenser, and radiator.
2) Are you ready for a coolant flush?
3) A plugged catalytic converter can make her run hot.
Old 06-28-2011, 06:57 AM
I replaced the thermostat, the expansion tank cap, flushed the system and blew away all debris from the radiator and the truck is operating good again.
Thanks for all the help.
The Following User Says Thank You to strap21061 For This Useful Post:
danielsatur (06-28-2011)
HELP!!Losing power when going uphill but get it back when on flat ground.... lynne2007 Sephia 3 03-28-2008 03:38 PM
shaking streering wheel when going uphill LaFlaca Escort 20 09-04-2006 09:10 AM
Slight Hesitation or Bucking when going uphill DelCoch Jimmy 5 07-15-2005 03:09 PM
2000 Dies when going uphill PieceOCrapCar Grand AM 2 12-31-2004 07:19 PM
93 buick has hesitation when going uphill BAMFSK LeSabre 4 12-06-2004 08:37 PM
