Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-12-2011, 03:18 PM
ND4SP's Avatar
ND4SP ND4SP is offline
Question Camaro drive by wire problem
I have an issue with a 2000 Camaro, was torn apart to fix lifter noise. While apart, cleaned throttle body. Now car won't stay at idle, either won't hardly run or if you touch the throttle pedal it screams to about 3 to 4 grand. Any ideas? Do I need to run a reprogram, teach for the throttle and computer???
2005 Buick Le Sabre: Cooper CS4s, Fram Air Hog and Silverstar Ultras Low beams and highbeams. LED tails and marker lights , brake/turn signals (front turns too) coming soon, just need to install resistors in circuit.
(Sold ) 1999 Intrigue: Fram Air Hog, Bridgestone Potenza G009(Love em, just a little road noise)Upgraded to G019 grids they were even better. Silverstar Low beams and highbeams. Led brake lights, all marker lights and third brake light.
Old 06-12-2011, 03:35 PM
danielsatur danielsatur is offline
Re: Camaro drive by wire problem
Caution - When cleaning a electronic Throttle body with a drive-by-wire system, don't mussel the throttle plate open otherwise the calibration is lost.
Old 06-12-2011, 05:44 PM
ND4SP's Avatar
Was Very gentle. Found the problem, vaccum line to the brake booster was disconnected. Thanks for the info!!
Old 06-12-2011, 05:56 PM
Usually you want the engine off, but the ignition key in the on pos.
Let a helper push the acceleator pedal down, the Drive-by-signal will open the throttle plate for proper cleaning.
Old 06-12-2011, 07:39 PM
j cAT j cAT is offline
with lifter noise using marvel mystery oil at 1 oz per qt of engine oil capacity slowly removes these carbon deposits causing the lifters to bleed off/or not hold proper oil....
obviously changing your oil when dirty and using non fram high quality oil filters like wix,purolator plus,or ac delco is the way to keep the engine running smooth and clean internally...
with these new engines use 100% synthetic oil at the proper recommended viscosity for your engine.
Old 06-19-2011, 01:58 AM
ND4SP's Avatar
Engine was torn down to get lifters out, took them apart, cleaned them and put back together. This car had a dead cylinder, Marvel mystery oil would not solve the mystery. Sludge formed in the engine from a bad seal on the throttle body, caused coolant to get into the crank case.
Have used Mobile 1 since it was out of break in period. Car runs great now.
Old 06-19-2011, 06:58 PM
you never mentioned a coolant failure causing your engine issues..
coolant in the oil will cause more than lifter issues..
good luck !
Old 06-20-2011, 05:21 AM
ND4SP's Avatar
Cool Re: Camaro drive by wire problem
good luck !
Oil was not like chocolate syrup , (which it would look like if significant amount was in the oil) looked just fine. Will be changing oil, and then changing oil again in a thousand miles, just to be cautious..
Nissan Cefiro - Idling/driving rpm problem fnasir Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 9 10-01-2010 10:35 AM
Camaro A/C Problems AgKyle2010 F-Body Problem Diagnosis 4 07-20-2010 07:32 AM
wiring short in sterring colum? danielgast46 F Series 5 03-23-2009 07:35 PM
97 Camaro Drive Shaft Problem/Question pingiii Camaro Discussions 1 05-25-2005 02:54 PM
F-body 95 Camaro Bose-Wiring System mode_x Camaro Discussions 2 01-28-2005 12:13 PM
