Old 06-11-2011, 04:12 PM
benstrickland98 benstrickland98 is offline
Metro Power Loss
1995 Geo Metro. 133 thousand miles. Loud rattle from engine, massive loss of power at lower RPM, low vacuum pressure, not blown head gasket (ruled that out), going to replace all vacuum hoses, advanced vacuum switch under distributor, and bypass catalytic converter, any other options I'm missing?
Old 06-11-2011, 08:03 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: Metro Power Loss
might be a burned valve, check compression
Old 06-12-2011, 03:44 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
With a rattle from the engine, it's almost certainly going to need a rebuild. Probably a broken piston, they're pretty common. At 133K miles it's getting close to where you'd expect it anyway.
As suggested get a compression gauge. Engine warm, all plugs out, wide open throttle. 200 psi factory, 150 psi minimum.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
2003 Sienna Gummed Engine, Power Loss, Clicking Nebeno Sienna 3 07-17-2010 07:05 PM
Power Locks, Power Antenna, Power Loss... keyplayah71 Park Avenue 3 10-27-2009 08:54 PM
Power Loss in an '89 4Runner toyotatech89 4Runner/GX470 6 08-07-2009 01:23 PM
97 7.3 power not what i used to be 86troopercrzy E Series 2 03-21-2009 11:03 AM
HELP.... Power to 5000RPM Power Loss -Joel- Performance 2 07-18-2002 06:15 PM
