Old 06-11-2011, 12:09 AM
christian86 christian86 is offline
Radio Wires
Hi I recently purchased a 1996 ford taurus and I pulled my Pioner 6 disc CD player out of my old car and got it mounted and ran the remote up front now I need to figure out what color is the Acessery wire and 12 volt constint
Old 06-11-2011, 06:40 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Radio Wires
Are you looking for accessory and constant wires in the trunk or in the cabin where the remote is?
-Rod
Old 06-11-2011, 07:25 AM
Re: Radio Wires
I figured insted of running wires to the front the trunk unit would be esierso trunk unit
Old 06-11-2011, 11:06 AM
shorod's Avatar
SHO No Mo
Re: Radio Wires
Pin 14 of C478 (red/yellow wire) at the Rear Control Unit is battery power. It is powered by 20 amp fuse 17 in the engine compartment fuse/relay panel.
From the factory wiring diagram it's not completely clear if the Red/Pink wire in terminal 10 of the same connector is a switched battery signal to the power antenna or not. I'd suggest you test that. If that one doesn't work, then you might try pin 17 (red/black) of the other connector (C411) which is labeled as "Ign/St" but is shown to only be hot with the key in "Start", not ACC or Run.
-Rod
F-250 radio problems...Need help farmboy401 F Series 0 05-10-2010 08:10 PM
'94 740 IL Radio Wire Harness Blocks which wire is what ? HELP ZONDERVANUS Technical 1 08-31-2007 07:49 PM
'94 740 IL Radio Wire Harness Blocks which wire is what ? HELP ZONDERVANUS 7 Series 10 05-15-2007 08:51 PM
90 Si wire harness/ radio wires Hyatus '88 - '91 Civic | CRX | Wagon | Shuttlee 0 08-22-2003 09:29 AM
98 accord radio wiring schematic ikeb21 Car Audio 2 12-29-2001 01:42 AM
