Old 05-29-2003, 10:19 AM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Water Pump?
Where is it located, and what are the symptoms of if going out? A friend of mine just started leaking all of his coolant fluids right under the crank pulley and he's getting a horrible noise from his engine. Kinda sounds like bearings or something. Any help would be appreciated.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 05-29-2003, 10:36 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
yup...that's where it is..pretty much next to/behind the crank pulley....
SOLD!
Old 05-29-2003, 11:38 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
yup..it is between the crank pulley and the cam pulley, inside the timing belt cover...it is driven by the timing belt...tell him to be real careful...when the coolant all leaks out, the gauge actually goes to COLD because it can't read the air temp in the coolant system (don't ask me how I found that out ) If he hasn't changed it in the last 40,000 miles, tell him to do a timing belt too, they are only ~$30 and he'll need to remove it anyway to get the pump off...or at least loosen the tensioner, so you might as well pop off the engine mount and replace the belt
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
