Old 06-10-2011, 02:54 AM
searcherrr searcherrr is offline
Send a message via AIM to searcherrr Send a message via MSN to searcherrr Send a message via Yahoo to searcherrr
Question Replacing the front Windshield Glass
Cannot get an inspection sticker without replacing the front windshield glass. How hard is it to do this and is it worth doing myself? I imagine you just remove the cowl and some other trim huh? Gonna need new trim? Special glues/adhesives?
Are all Windstar front glass windshields the same shape? I think they all have the same frame body, so wouldn't that mean all year windshields are the same?
Thanks!
1995 3.0L 3000GT NA FWD ATX - ProwlerGT on 3si.org
1995 3.8L Ford Windstar GL
"I drive the newest 1995 Ford Windstar anywhere..... when its not broken."
Old 06-11-2011, 03:14 PM
Windstartled Windstartled is offline
Re: Replacing the front Windshield Glass
It depends on your definition of "hard", the job is definitively tricky. Removing the cowl and the trim is the easy part. Trim is made from a pliable material and not glued on so it pulls out readily, if it's still in good shape you may reuse it over the new windshield. There's no caulking to speak of but the glass is glued on the frame with some sort of rock-hard urethane epoxy that you need to cut through with windshield wire or a specialized tool.
Old 06-12-2011, 08:16 PM
Erik2002Winnie Erik2002Winnie is offline
not worth it imo.
you are talking under 200 to have it done.
unless you know what you are doing, you will likly leak and you will spend close to as much
Old 06-29-2011, 12:10 AM
Thanks guys. I'll probably have a glass shop do it. Some things just aren't worth DIY.
Old 06-29-2011, 07:00 AM
12Ounce 12Ounce is offline
Be sure to call your insurance guy ... some states require insurance companies to replace windschields even though you have only "liability" insurance. Considered a safety item and good for all the motoring public. So you may get it for "free" ...or at a reduced cost.
replacing the front bearings brainfrez Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 10-02-2005 01:05 AM
replacing the front bearings brainfrez Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 09-30-2005 05:46 PM
replacing the front cv's got a ? eclipseracer92 Off-Topic 1 08-07-2004 11:20 AM
How do I remove/replace the front grill on the 2004 SE-R? shawnmandel Sentra | 200SX (USDM FWD) 2 04-19-2004 01:27 AM
