Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 06-09-2011, 08:33 PM
SsHaDyGt SsHaDyGt is offline
Fuel pressure regulator?
Hi all,
I have a 93 wrangle 4.0L
The jeep has been having trouble starting, it will turn over for longer than it should and sometimes won't start until hold the key on for a few turns. After it starts, it runs fine.The issue occurs regardless if the engine is cold or hot.
I had tested the fuel pressure with a pressure tester at the rail and found that there was no pressure when the key was in the off position (is this normal) I then also found there to be no pressure after turning the key and hearing the fuel pump prime for a few seconds.
I did a tune up plug wires cap rotor fuel filter and I even changed the fuel pump.
I haven't been able to test the pressure again after changing the fuel pump but the jeep is still having the same starting issue.
I'm going to test the pressure again but I am leaning toward a faulty fuel pressure regulator.
Is there supposed to be pressure in the rail at all times?
Thanks
1998 silver gtp, GM performance Handling kit ,cold air intake, KYB struts ,HD supercharger coupler ,Gatorback belts ,U bend delete ,NGK TR6 plugs ,DHP PCM, Electric exhaust cutout - SOLD
98 White GTP, N* TB, 3.0 MPS pulley, SLP headers, 1.9 Rockers, 105# springs, ZZP PCM, Flowmasters, GM performance Handling kit, FWI, GMPP springs, U bend delete, SSIC, Ported LIM, Autolite plugs, ported SC, 12" brake upgrade with slotted cross-drilled rotors,
Old 06-15-2011, 08:19 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Fuel pressure regulator?
Lots of posts on here about fuel issues at startup. Most are cured by turning the key to the on position and letting the fuel pump run for a few seconds until it stops; but it sounds like you have already done that.
I'd agree that checking the fuel pressure regulator makes sense. I don't know if it's spec'd to have fuel pressure when off; IMO pressure would bleed down over time.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 06-15-2011, 08:45 PM
inafogg inafogg is offline
i'd recheck fuel pressure,especially for a leak down.it sounds like the system is bleeding off to much/to fast.i would not condem pressure regulator.
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Reading high fuel pressure (carbureted) caffeineaholic Caprice 16 09-25-2010 02:55 PM
For Sale New adjustable fuel pressure regulator Malbe3 Parts for Sale 0 08-07-2010 06:32 PM
'90 mustang will bad fuel pressure regulator cause idle surge? fords4me Mustang Problem Diagnosis 1 11-27-2009 02:18 PM
96 Tahoe Fuel Pressure Issues mcmyket Tahoe 3 09-17-2009 09:09 AM
97 Blazer low fuel pressure new pump stalls in gear ChevyFamily Problem Diagnosis 6 06-05-2009 06:12 PM
