Go Back   Automotive Forums Car Chat > Nissan > Older Pickups
Old 06-09-2011, 07:13 PM
LordZarkon LordZarkon is offline
Valves noisy after Timing chain replacement
Just finished replacing the timing chain, tensioner, guides.on my 1997 Hardbody 4x4 with the KA24E. It just seems like the valves are ticking hard. I was careful to put the filled oil pump together with the notch and punchmark aligned, looked thru the dist hole to make sure the tab was at the engine front. I removed the fill cap on the valve cover, and some oil splashed ou occaisionally. I added oil back to the engine... I'm stumped! I don' want to run it if the valve train isn't getting enough oil. Any ideas?
Old 07-21-2011, 12:15 PM
Pdx88lude Pdx88lude is offline
Thumbs up Re: Valves noisy after Timing chain replacement
Valve lash check your valve clearance or you could be a tooth off
The Following User Says Thank You to Pdx88lude For This Useful Post:
LordZarkon (07-21-2011)
Old 07-21-2011, 03:11 PM
Actually, from a 240ZX website I learned that the hydr. valve lifters just needed to refill w/ oil. Blipped the throttle a couple times and she settled in.
timing chain replacement bigjimslade Engine 12 01-27-2010 09:57 AM
92 buick roadmaster, still fighting surging idle after timing chain swap. rnj Roadmaster 2 01-10-2009 02:09 PM
No start after timing chain replacement leftyspike Cavalier Problem Diagnosis 4 06-30-2008 04:29 PM
99 Explorer Making Strange Vibration After Timing Chain Replacement De4thStr1ke Explorer | Explorer Sport Trac 5 02-27-2008 02:57 PM
95 Maxima - Timing chain replacement mkgupta Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 01-18-2004 01:49 PM
