Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 06-09-2011, 01:11 AM   #1
XGamesJ6
XGamesJ6's Avatar
2004 Chevy Tahoe 4WD ZR1 Gauge issues!
Hello, My friend has a 2004 Chevy Tahoe 4WD ZR1 where the speedo, tach, and oil pressure gauges do not work, the tach is stuck at around 4000 and the speedo and oil just doesnt move, sometimes the speedo is pegged at the high end though.
I used an OBDII scanner and found i can read the speed and tach from the ecu without issue while driving the vehicle. so that leaves me to believe the speed sensor and such are still good.
I've done some research and found these vehicles have faulty Gauge Clusters that need to be replaced. Does that sound right to y'all?
I found a company that will rebuild and re-calibrate your gauges, all you have to do is send them out and they do it and send it back. Does that sound like a good way to go when it comes to fixing this issue?
2009 Pontiac G6 2.4L L4
2007 Buick Lucerne CXL 3.8L V6
2007 Chevrolet TrailBlazer LT 4.2L L6
1993 Oldsmobile Cutlass Supreme SL 3.1L V6
XGamesJ6 is offline   Reply With Quote
Old 06-09-2011, 09:11 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
Re: 2004 Chevy Tahoe 4WD ZR1 Gauge issues!
Yes you can send it off for a rebuild .
But
You may have a week or two wait.
Or check you local parts place and see if Dorman makes a exchange for it.
No wait for rebuild.
Also check dealer for a recall on it.
MT
MT-2500 is offline   Reply With Quote
2004 Chevy Tahoe Service Tire Monitor Warning LadyTahoe Tires and Wheels 7 05-20-2009 01:21 PM
'04 Tahoe Range/Fuel gauge problem. usn_622 Tahoe 2 02-21-2009 10:58 PM
2004 Chevy Tahoe Hood Adjustment/Alignment terry3001 Tahoe 1 08-31-2004 06:27 PM
2004 Chevy Tahoe, Removing the governor? feraldarkness Tahoe 4 08-30-2004 04:49 PM
2004 Chevy Tahoe Rims/Tires for sale ADyingDevotion C/K 0 01-15-2004 07:24 PM
