Old 06-07-2011, 07:53 AM
S10SNODOG's Avatar
S10SNODOG S10SNODOG is offline
Best u joints on the market
I need to know Bad u joint company out there I've gone through u joints like crazy And theircheap shit. 2003. V6 160,000 stock who makes the best u joints on the market
Old 06-07-2011, 09:14 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Best u joints on the market
Precision come to mind.
As with any parts Most parts places have a cheap and good line.
Always ask for the best.
Or you can go to the dealer and get the oem joints.
Also good installation has a lot to do wth U joint life.
MT
Old 06-07-2011, 08:03 PM
4x4 blazerguy 4x4 blazerguy is offline
My first thought is they are not being installed correctly. I have changed hundreds of U-Joints in my career & have never had one fail under normal use & maintenance. I have twisted a couple apart in my day. Even twisted a driveline & never broke the U-Joint. For 45 years I have been into places with 4x4 vehicles that were tough to say the least.
Old 06-08-2011, 08:15 PM
S10SNODOG's Avatar
the BEST U JOINTS for S - 10
03 v 6. 4 X 4. 160,000 miles STOCK I need to know Who makes the best u joints on the market I am having horrible experience with u joints I go through a set Once at every year im getting a little. Vibration at 65 70 mph only when I let off the gas the u joints are definitely making noise the usual clunck into reverse so ill start there also had just had to replace the pinion seal in rear end..........it
does not leak now
Old 06-08-2011, 08:47 PM
j cAT j cAT is offline
Re: the BEST U JOINTS for S - 10
does not leak now
just make sure its made in the USA...also use lithium grease when you install these joints and grease them every 5,ooomi they should last unless the angle is off because of non oem height changes.........
Old 06-09-2011, 10:11 PM
old_master's Avatar
Advisor/Moderator
Incorrect pinion angle, cheap quality joints, or improper joint installation can all cause premature joint wear. The most common cause for incorrect pinion angle is as jcAT mentioned, front and or rear chassis ride height is out of specification. Several things could cause it to be incorrect: 1) Someone messed with the torsion bars that didn't know what they were doing. 2) Body or chassis lift improperly installed on the vehicle. 3) Torsion bars and or rear springs are sagged out and need replacement. If pinion angle is out of spec, there isn't a joint made by any manufacturer that will last.
You have to know how it works,
to figure out why it doesn't.
Old 06-10-2011, 06:14 AM
S10SNODOG's Avatar
Yea but this truck is BONE STOCK. No lift nothing the tires are. 31.50 S THAT'S a slight bit bigger than stock tires
Old 06-10-2011, 03:42 PM
old_master's Avatar
Advisor/Moderator
Tire size will not affect chassis ride height, (if they're all are the same size). The vehicle is 8, almost 9 years old: During that time, torsion bars and springs weaken which causes chassis ride height to change, which in turn will affect pinion angle. Very easy to check, let me know if you need the specs.
Old 06-26-2011, 05:37 AM
rprough's Avatar
rprough rprough is offline
MOOG chassis products have allways served me well. Just make shure you match mark driveshaft/u-joint relationship before removing shaft or u-joint. This is important for balance.
God Bless America
lookin for the best header for the money 20HondAccord02 RSX 8 02-07-2007 09:03 AM
The Best Job For The Best Photochoppers corvettezman Graphic Manipulation 4 03-29-2003 02:24 AM
who makes the best chip for 2002 hx? where is the best place to get spoon assessories defuse411 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 04-25-2002 01:59 PM
WHats the best engine for the mr2? gHeTtOAZNbOi206 MR2/MR-S 7 03-06-2002 05:22 AM
