Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-29-2003, 08:37 AM
AgonEbodE AgonEbodE is offline
Post Head Gasket Blown?
Yesterday as I'm driving my 1995 Eclipse GST, I started to feel a jurking feeling in the acceleration. I checked my oil dip stick to find bubbles. Also the check engine light came on. How do I go about extracting and reading the ECU codes. Also, could my head gasket be blown? Those that know, please reply....thank you so much.
Old 05-29-2003, 09:14 AM
aves911's Avatar
aves911 aves911 is offline
Massive Genius
Send a message via AIM to aves911
Don't assume its a head gasket yet.
You can get you ECU codes pulled at any Autozone or Napa, they'll have a scanner you can use.
Also,
what do you mean by "bubbles in the oil", if the hg is blow there will be coolant in the oil or oil in the coolant, it looks like greyish sludge. Jerking durring accelerationg could be anything. I would suspect the ignition. Go get you codes pulled and go from there.
Hope that helps,
Peace
"this is a funnie thread..
we have a poser who keeps posting information that doesn't fit together..
and aves911 keeps correcting him"
Old 05-29-2003, 09:55 AM
The bubbles represent the water getting into my oil. We don't have an autozone here in the Virgin Islands. We do have Mitsubishi Dealers, but if I could pull the codes on my own Then that's the route I would like to take first. Is there a way to read codes on a turbo? Again thanks for your help.
Old 05-29-2003, 11:09 AM
turboawdgsx turboawdgsx is offline
You can check out www.digitaltuning.com. They sell a pocket logger that you can use with a Palm Pilot. What year car/model do you have?
Rob
"Got car lenghts?" or "You can turbo anything but can't make stupid people smart, something wrong with this picture?"
Old 05-29-2003, 02:22 PM
Thank you for your reply, I have a 1995 Mitsubishi Eclipse GST. I was wondering if there is a way of reading codes without machines. You know the older vehicles u can use jumper wires and connect to diagnose box. Well is there anything similiar to that feature? Thanks a lot.
Old 05-29-2003, 07:22 PM
Japmetal
Guest
Posts: n/a
If you think you've got water/coolant in your oil, check your oil filler-cap;
If it's 'normal' coloured [I assume you know what colour oil is meant to be] you should be ok.
If there's a creamy-brown residue on it, your head gastket is gone.
Old 05-30-2003, 08:24 AM
I will do that today, thanks a million. Do you know how to read the codes on a Mitsubishi without having a scanner?
Old 05-30-2003, 11:14 PM
Spectrum Spectrum is offline
Send a message via ICQ to Spectrum Send a message via AIM to Spectrum
You cant read 2G turbo codes without a scanner. And have you done a compression check?
Old 06-02-2003, 07:19 AM
O I C. Thanks for the information.
Old 06-02-2003, 10:49 AM
humbleclipse humbleclipse is offline
you can check your own ecu codes by putting the key in the ignition and going on off on off on and then count the number of times the engine light blinks and compare it to the codes in the repair manual, like hanes or something
your headlights look good in my rearview
Old 06-02-2003, 11:06 AM
Great!!! This is the method I was looking for, but everyone said it couldn't be done. So all I have to do is turn to on-off-on-off-on and then the codes will blink just like that on the check engine light? I will try that this afternoon after work. Is there a site on the internet where I can get the ecu codes? Thanks A Lot Humbleclipse.
Old 06-02-2003, 11:41 AM
there is a site but i forgot it but i have the codes myself but left my book at home so i will post tomorrow morning for ya
Old 06-02-2003, 02:39 PM
The on-off-on-off-on thing only works on non-turbo Eclipses.
Old 06-03-2003, 10:09 AM
i tried it on my non turbo and it didnt work and was told it only works with turbos, so i dont know for sure
Old 06-03-2003, 11:15 AM
it only works on 2G non turbos, and was the light even on?
