Old 06-07-2011, 11:53 AM
ZiggyPA ZiggyPA is offline
difference between thermostats?
For the 91 PA Rockauto lists a whole bunch of different thermostats. I want to get a Gates (same warehouse) but what is the difference between a "regular thermostat - reverse poppet" and "premium thermostat - superstat"?
Old 06-22-2011, 10:29 PM
y2kpa2's Avatar
y2kpa2 y2kpa2 is offline
Village Idiot
Re: difference between thermostats?
i do not think it makes a difference just as long as the temp is the same as o.e.m 195 if you want gates go to a napa store near you
My Fleet 2000 F-150, 2012 Chevy Impala LTZ
Old 06-22-2011, 10:52 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
I prefer the Stant SuperStat over the regular/conventional reverse poppet. BTW, they may not have a NAPA store in Holland.
Stant Premium Thermostat; Unlike conventional thermostats that continually open and close to achieve the proper operating temperature and flood the engine with coolant, the Stant SuperStat® thermostat has a patented v-notch, non-linear design that reduces cycling by precisely metering the amount of coolant needed to maintain proper operating temperature. The v-notch provides a small inital flow. As the engine heats up, the v-notch gradually opens wider, metering coolant into the system until the desired engine temperature is reached.
The high strength stainless steel flange is burnished to a bright finish for additional stress relief and added corrosion resistance.
Old 06-25-2011, 12:50 PM
Jrs3800 Jrs3800 is offline
I agree and also use the super stant...
Old 07-10-2011, 01:53 PM
I got the superstat, it was only like $1 more anyway.
But I can't get the thermostat housing to open. Those 2 bolts are ridiculously tight. It seems I'm either gonna break the wrench or the bolt...
Or is there some trick to this?
Also the bolts are different sizes. The rear one is 3/8" but what size is the front one? It seems a bit loose for 10mm metric but it's no 3/8" (equals to 9,5mm) what is it if it's not a 10mm?
Differences between '05 and '06 1.6 Engines? edr_bug Aveo 0 08-06-2009 11:51 PM
Whats the difference between the different models? Jaxal General Discussion 0 02-10-2007 11:45 AM
What is the difference between the Navy and Electron Blue psycovette Corvette 2 07-22-2002 07:31 AM
Differences between Evo V and Evo VI srfsup97 Lancer 3 10-30-2001 07:18 PM
Difference between European, USA and Japanse Supras?? mheier General 5 10-16-2001 08:11 PM
