Go Back   Automotive Forums Car Chat > Nissan > Quest | Presage | Serena
Old 06-07-2011, 07:11 AM
jeep2002 jeep2002 is offline
2004 Quest will not start
Hi all....I need urgent help with a 2004 Quest. We changed the starter this weekend and everything checked good for 4 or 5 starts. It wasn't driven at all for the rest of the weekend. Yesterday it started fine and was driven about a 1/4 mile then sputtered and shut off. Now as soon as you start it, it will shut off. I checked the connectors and vacuum lines to make sure that they were connected...we pulled the inlet duct between the air box and throttle body to get the starter out. Please help as I am out of ideas...thanks
Old 06-08-2011, 06:31 PM
tempfixit tempfixit is offline
Re: 2004 Quest will not start
You need to determine if you have a fuel problem or a spark issue when it dies. Spray some carb cleaner in the throttle body after it shuts off to see if start, if so it is a fuel related problem. If no start then check for spark.
Old 06-09-2011, 07:06 AM
it starts but the idle bounces and it starts sputtering. when it sputters there seems to be alot of back pressure between the throttle body and the maf. We looked at everything and dont see anything that was knocked loose during the starter change. we did find this canister that the top vacuum line is not connected to anything. From what I can tell, is it a transmission breather that does not get connected? Pics attached
Old 06-10-2011, 04:38 PM
IS the check engine light on???? If so can you get the codes and post?? Not sure where the back pressure would come from but it would affect the maf sensor reading to the ECM.
Will not start (sort-of randomly) caffeineaholic Caprice 7 08-04-2010 08:13 PM
2004 Lesabre will not start when hot. Notacarguru LeSabre 1 08-31-2009 08:31 PM
2004 A4 Will Not Start nitro56 '04+ 3 05-10-2008 09:13 PM
2004 Passat will not start Cecil Turnbow '97+ 4 11-17-2007 02:00 PM
2004 Rio will not start JWsPhotoNation Rio | Rio Cinco | Pride 2 06-22-2007 09:07 PM
