Old 05-29-2003, 05:55 AM
Touge180 Touge180 is offline
Oil question
The last time i changed my oil i jused 10W 40 but it ran low so i added more my question is the next time it go low again can i added 20w 50 insted of the 10w 40 or will this mess thing up.
Old 05-29-2003, 06:11 AM
redmanjd redmanjd is offline
what do you mean low? your oil level, if it is going low you have a leak or you are burning i thought the recomended is 5w 50. the thicker oil you use the more resistance you will have on you internals
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 05-29-2003, 06:51 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
your not really meant to mix oils, so i am told,
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 05-29-2003, 09:19 AM
im burning oil i think but i can use 5w 50 right
Old 05-29-2003, 09:46 AM
i think the first number is the weight (thickness) and the second is the temp range i think
95 b18b
Old 05-29-2003, 12:52 PM
CRXtc CRXtc is offline
Banned
10w 40 is FINE for higher temperatures (IE ARIZONA or the like) and you can mix the oils.....
Old 05-29-2003, 01:12 PM
you just dont want to mix synthetic with non
95 b18b
Old 05-29-2003, 01:37 PM
Banned
uhhh so then what is a synthetic blend?
Old 05-29-2003, 03:29 PM
l2ice rocketz l2ice rocketz is offline
Send a message via AIM to l2ice rocketz
You'll be able to tell from the labels, it'll say "synthetic". Personally I think if you truly love your car, u can indulge it with some of that stuff. I've heard that you can get about an extra 1000 miles before an oil change, and burns much less than regular old oil. Got some for my friend's 93 camry, the car was just purring after we put in 3.7 bottles of that stuff. =P
Old 05-29-2003, 10:15 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
The 5w30 (for example) is what the viscosity of the oil will be like at cold and hot oil temperatures, ie when the oil is cold it will act like 5 weight oil (thinner oil), when the oil is hot the oil will act like 30 weight oil (thicker oil).
All the variations in viscosity will suit different situations (ex. 10w40 for summer or 5w30 for winter). But for most driving you can use 5w30 all year round. Check your manual.
BTW, if you are burning oil try going to a thicker oil like 10w40, it should cut down the smoke (or an oil additive like RESTORE if you have low compression or something that will swell you valve guide seals or something that says "Miracle cure" on the label. ) Good luck.
Old 05-30-2003, 01:48 AM
BullShifter's Avatar
Newer BMW's oil change every 15,000 miles with their synthetic. No thanks, I would do it atleast every 5,000miles in that case.
Old 05-30-2003, 06:57 AM
all oils detergents break down at 3000 miles . but they still lubricate the only thing is it doesnt clean you engine and starts leaving deposits. bet synthetic is the shizzznit
95 b18b
Old 05-30-2003, 08:19 AM
Banned
this is not true
Old 05-30-2003, 09:16 AM
explain?
95 b18b
Old 05-30-2003, 09:26 AM
Civic Jim's Avatar
i use mobil 1 and change it every 6k
B16A1 I/H/E
4TH GEN UK SITE
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
