Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-06-2011, 07:07 PM
ASJT3 ASJT3 is offline
Send a message via AIM to ASJT3
AC - High Pressure on low side
Hey guys,
I replaced my accumulator and orifice tube and retrofit the AC system on my '87 wagon last fall and the AC ran great until it leaked out a month later. Unfortunately I had forgotten to replace the o-rings so I figured I'd just leave it until the summer.
Well here comes summer and I remove the fittings on the accumulator to replace the o-rings, then start to recharge the system. The pressure on the low-side starts getting up to 55psi, then the compressor comes on and takes it back down until it shuts off. This happens while I'm recharging the system repeatedly; compressor is only intermittent. After 1.5 cans of R134, I started to get worried. When I turn off the AC, the pressure on the low side gets up to around 150 PSI or more.
I'm worried about adding more refridgerant and can't remember, am I supposed to take the pressure reading with the compressor running or not running?
Thanks,
Alex
Old 06-06-2011, 09:37 PM
inafogg inafogg is offline
Re: AC - High Pressure on low side
Originally Posted by ASJT3 View Post
Hey guys,
Thanks,
Alex
you want to check readings while compressor is running.it sounds
like the comp is cycling on/off because system is low.
you didnt say if the system was evacuated,or that the system was holding.if it wasnt you can run into more problems.hopefully you just for got to mention.
Good luck
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 06-06-2011, 09:56 PM
brcidd's Avatar
brcidd brcidd is offline
150 psi static pressure means you have a non-condensible in the system-air.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 06-07-2011, 04:20 PM
Well I checked it shortly after posting and realized that I had cracked the pressure sensor on the accumulator by over-tightening it. The pressure sensor was a GE type "F". I've got four GE sensors of type "40","46","48", and "A". Would any of these be ok to use as a temporary replacement?
[EDIT] I believe this is termed the "clutch cycle switch"
much thanks,
alex
Old 06-08-2011, 08:44 PM
j cAT j cAT is offline
when you open the system up you must use a vacuum pump before thinking of adding refrigerent...when it is like now very hot very humid you now have alot of moisture in there and that is going to destroy this ac for sure.
when the compressor is off the low side pressure will rise..150psi is on the higher than normal side but if it is 100degf out could get that high.
AC high pressure Low side twiztid420 2nd Gen 00-05 0 07-17-2010 01:11 PM
Expected High and Low side AC values. manlystanley Caravan | Voyager 2 06-28-2007 02:06 PM
a/c high pressure on low side mustangd Crown Victoria 0 06-09-2007 09:26 AM
Which is the High pressure and low pressure line for A/C? mistervelasco 3 Series 1 08-05-2005 09:03 PM
AC Low Side Pressure Too High (70 psi) fdunford Windstar 2 05-28-2004 11:30 AM
