Old 06-06-2011, 03:44 PM
GreggT GreggT is offline
No Air!
Well the air works but it won't blow through the dash vents, its all blowing on the floor even when i change the selector. Fan works fine. It always happens after about 15 mins of driving.
Old 06-06-2011, 04:00 PM
Re: No Air!
I think I've narrowed it down to the selector switch, the one that selects defrost, floor, ect. Nothing happens when i turn it, any ideas?
Old 06-07-2011, 12:44 PM
rkvons's Avatar
rkvons rkvons is offline
Re: No Air!
People will want to know the year and model of your vehicle. Also, what specific climate control do you have. Is it auto, or manual? Sometimes the output of air is controlled y vacuum. It might be worth opening up the dash and pulling your climate control out and take a peak at the vacuum lines that go to it, if any. They may be kinked or twisted. Perhaps when an after market radio was installed, or something. It could also be the control itself that has gone bad, but I don't know what control it is. They are supposed to be greased up and yours may have dried up a bit.
Old 06-07-2011, 03:12 PM
Re: No Air!
its a 2000 GP GT, has manual climate control, factory radio. I checked the vacuum line from the intake and it was fine. It works great for about 15 mins or so, then stops blowing, don't get it! After it cools down it work fine again.
Old 06-07-2011, 03:24 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: No Air!
This is definitely a vacuum supply issue. Double check the hard plastic line under the hood where it runs near the battery. If that checks out ok, it may be the vacuum storage canister under the dash, as they are known to crack and leak with age.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 06-07-2011, 03:57 PM
Re: No Air!
where is the best spot to find the vacuum canister? Through the glove box maybe? Is it on the passenger side?
Old 06-07-2011, 04:04 PM
richtazz's Avatar
Re: No Air!
the storage canister is behind the floor duct under the center of the dash. It is sort of rectangular in shape and is held in place by two bolts. Should have GM part# 10403762 on it.
Old 06-07-2011, 04:09 PM
Re: No Air!
do i have to remove the centre console?
Old 06-07-2011, 04:18 PM
richtazz's Avatar
Re: No Air!
It's tight, but you shouldn't have to remove the console. It's actually under the dash (directly under the HVAC control head) slightly forward of where the console meets the dashboard.
Old 06-07-2011, 04:20 PM
Re: No Air!
i will check it out, thanks for the tips!
Old 06-21-2011, 03:35 PM
Re: No Air!
i checked the vacuum canister, definatly have vacuum coming into it, it looks fine but i didn't remove it, should i? where do they usually crack?
Old 06-22-2011, 04:25 PM
Re: No Air!
i removed the vacuum canister, no cracks everything looks good, lots of vacuum going in but I'm still stumped, a/c still quits after about 15 mins of driving! help!
