Go Back   Automotive Forums Car Chat > Hyundai > Tucson
Old 06-06-2011, 11:27 AM
drdrew33 drdrew33 is offline
2005 Tucson V6 sludge
I just did my first oil change on a recently purchased 05 Tucson. I noticed when I took the oil cap off there seemed to be a lot of sludge in view in the motor, I cleaned what I could. My question is has anyone ever used Seafoam in one of these Hyundai engines, and if so, how were the results? I used to use it in My 99 Rodeo and was amazed at what came out during oil changes.
Old 06-11-2011, 01:20 PM
DSHornet DSHornet is offline
Re: 2005 Tucson V6 sludge
I recommend using Seafoam, or any other cleaner, with extreme caution. The last thing you need is for the cleaner to knock loose a big piece of sludge that then plugs up an oil passage and starves a bearing or the valve train of lubrication.
If it was cold weather, I would suggest using a high quality 5W-20 oil at the next change, run it on the highway for an hour or two, and drain/refill using a Hyundai OEM filter. Since it's summer (in the northern hemisphere ), using 10W-30 might be a better idea. Let the detergents in the oil work for you.
Don't expect a quick, easy fix to the problem. It might take months and several oil changes to clean up the mess.
Paw-paw Don, y'all
______________________________________________
Favorite saying:
"One need never apologize for exercising the Golden Rule"
The Following User Says Thank You to DSHornet For This Useful Post:
drdrew33 (07-06-2011)
1997 windstar mysterious brown sludge in cooling system FLAWIND Windstar 11 07-16-2012 08:53 PM
2005 stalls and stalls and stalls... MN Ding Dong Focus | C Max 3 06-27-2011 07:52 PM
FOURTH battery in 4 years of ownership 06 Tucson momguam Tucson 1 10-31-2010 03:07 PM
2005 G5 - V6 Clicking Noise in engine donnap1957 G6 9 02-26-2009 07:44 PM
question on 2005 Tucson NYKMBarker Tucson 1 06-27-2007 01:45 PM
