Old 06-06-2011, 09:40 AM
wilkerson3 wilkerson3 is offline
Should I reseal valves on '01 Taurus AC compressor?
We had the ac recharged on an '01 Taurus we just bought. Leaked out in a couple of weeks. Shop will charge ~$800 to replace compressor, dryer and tube. (Just about half the value of the car.) Can the valves just be resealed/replaced on a compressor? Or is it not worth it?
Old 06-06-2011, 12:57 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Should I reseal valves on '01 Taurus AC compressor?
Did the shop actually investigate to find the source of the leak, or are they giving a "worst case" estimate based on rather common areas to cause leaks? The valves in the compressor are not practical to "reseal" but the schrader valve can be replaced relatively easily if the system is evacuated of refrigerant.
-Rod
Old 06-06-2011, 05:08 PM
Didn't think to ask them. They were just giving "worse case scenario" and the $ amount to fix the problem. I was just planning on purchasing and replacing the compressor, but thought I'd ask about the valves first.
Thanks
2005 Ford Taurus Siezed A/C Compressor HBTaurus2005 Taurus | Taurus Wagon 10 07-06-2014 02:01 PM
rotten Bleeder Valve on ABS Compressor/Proporsioning valve nqc2k Alero 2 04-02-2007 03:31 PM
'01 Taurus Moisture in Headlight Lens dan in pa Taurus | Taurus Wagon 3 02-14-2006 05:56 AM
belt chirping and a dragging noise '01 Taurus davidj0 Taurus | Taurus Wagon 9 04-17-2005 06:16 PM
