Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 06-06-2011, 09:02 AM
starryeyed starryeyed is offline
question about 2006 ford expedition EB suspension compressor?
question about 2006 ford expedition suspension compressor?
Our 2006 EB expedition was in a motor vehicle accident and was hit by the compressor and since then our suspension compressor is not working. If we jump the compressor with hot wire the bags don't pump up. Compressor suspension doesn't come on and all fuses are good. Want to also add that the compressor is not damaged as a result of the accident. How can we fix this?
Old 06-12-2011, 02:35 PM
ipacketeer ipacketeer is offline
Re: question about 2006 ford expedition EB suspension compressor?
When you jump the compressor if the compressor is runing but the bags are not inflating, I would first suspect the feeding lines, from the compressor to the air bags. If the lines are in good shape, there is no disconnection or restriction, then check the air bags.
Good luck.
1999 Ford Expedition (E.B. Edit.) -Loud Grinding / Crunching noise in first gear UnluckyDucky Expedition 0 03-13-2009 06:03 PM
