Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 06-05-2011, 09:06 PM
spddmn1 spddmn1 is offline
Y pipe bolts
I'm replacing the exhaust on a 03 Escape. I'm replacing the Y pipe back. I'm stuck here because i can't figure out what size the nuts on the Y pipe studs are. If i use a 14mm socket it's loose, if i try a 13mm socket it won't fit on it. Same with a 1/2 or 9/16 socket. Anyone replace the exhaust on one before & know what size socket i need?
Old 06-06-2011, 02:08 PM
65comet's Avatar
65comet 65comet is offline
Re: Y pipe bolts
It is suppose to be 14mm, but they rust off an outer layer and become smaller with age. I had to take a sawzall and cut them off on my 02 when I couldn't get visegrips, 24 hour soaking with a good penetrating oil and heat from a torch to work.
Old 06-25-2011, 06:38 PM
rhandwor rhandwor is offline
Re: Y pipe bolts
Napa or Sears sell damaged nut removers. You will need new nuts when done and the stud may break. Soak good with PB blaster.
How to change gasket on cross pipe at rear of engine cmar2112 Trooper | SLX | Bighorn | Wizard 1 04-21-2010 11:50 PM
99 DX header + test pipe sentoyang '96-'00 Civic 1 10-26-2009 02:34 PM
how do I get down pipe bolts out? johnlivingston Century 3 07-11-2009 09:11 AM
j-pipe bolts mitsu3kgt Off-Topic 2 02-23-2007 01:39 PM
down pipe bolt dmbrisket 51 '88 - '91 Civic | CRX | Wagon | Shuttlee 2 06-08-2005 01:44 PM
