Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 06-05-2011, 10:23 AM
Rajan Rajan is offline
99,Saturn SL1, Day lights are off
Hi,
Few days ago, Day lights turned off . Indicator on the dashboard
was blinking once in a while. Now Days lights as well as indicator are off now.
Does DSL stand for day light ? If yes, there is black unit inside the fuse box for
DSL. How to take out that one.
Any help/solution would be appreciated.
Thanks.
Old 06-05-2011, 07:37 PM
Cat Fuzz Cat Fuzz is offline
Re: 99,Saturn SL1, Day lights are off
Your post is about as clear as mud. Can someone translate?
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 06-06-2011, 09:04 PM
Sorry ! I explain the issue one more time. Usually, Both Daytime running lights and indicator in the dashboard are on while driving. But Indicator had been flashing once in a while for few months. Now both Daytime running lights and indicator are off and not turning on.
I think, DRL stands for Daytime running lights. It is a five pins unit in
the fuse box. I've already checked this one but it seems to be OK.
Any other solution ?
Thanks.
Old 06-07-2011, 10:38 AM
denisond3 denisond3 is offline
Do the headlamps work normally when you turn them on at night? And do both of them work, on both low-beam and high-beam?
The daytime running light module turns the headlamps on at a reduced voltage level. If the 'headlamp' symbol on the dashboard was blinking, it must have gotten as indication that the DRL module was bad, or possibly that one of the headlamp filaments is burned out.
If the headlamps work at night, that would be where I would stop worrying about fixing it. At least until the guy doing the annual safety inspection would tell me I have to fix it. (In my state they usuall dont care.)
99 Saturn SL Won't Start! turtleisland SC/SL/SW 5 08-13-2009 09:52 PM
99 Saturn SL1 Engine oil consumption Rajan SC/SL/SW 9 09-11-2006 12:23 AM
99 saturn SL1 revs high on cold start nuwt SC/SL/SW 6 02-20-2006 07:45 AM
99 Saturn SL1,Fuel filter replacement Rajan General Discussion 1 03-13-2005 09:52 PM
99 Saturn SL1,Radiator Cap location Rajan SC/SL/SW 2 02-27-2005 10:11 PM
