Go Back   Automotive Forums Car Chat > Cadillac > Seville
Old 06-04-2011, 09:58 PM
hellishogre84 hellishogre84 is offline
Angry brake help please for 96 seville sts
i have replaced the crossover hose and brake lines plus the master cylinder bled everything out and i have no pedal when i start the car the pedal goes to the floor i put it in gear and i push the pedal the driver side will stop and the passenger side will stop or keep turning if you pump it up you can get the passenger to stop but usually only for a lil bit before the pedal goes to the floor again the it will start turning i really need to get this car going please help me figure out whats wrong
Old 08-25-2011, 07:30 PM
xtrapimpy xtrapimpy is offline
Re: brake help please for 96 seville sts
have you found a solution to your problem? you need to make sure that when you bleed the brakes you have to bleed ALL the brakes. and when doing this you need to start with caliper the furthest from the master cylinder.... hope this helps some one out there...
Old 08-26-2011, 08:39 AM
maxwedge maxwedge is offline
A990 racer
This usually occurs because the ABS unit must be bled using a scanner.
Brake Help Please!!! RBeach Blazer 9 10-19-2005 06:21 AM
91 Jimmy Brake HELP PLEASE! RBeach Jimmy 4 05-21-2005 08:38 PM
Rusty Brake Lines on my Seville STS ('98) Cedricduck Seville 0 06-25-2004 03:16 AM
brake help please... all4freedom Wrangler 2 10-11-2003 06:32 AM
brake help please pgringo69 Accord/TSX/Accord Hybrid 0 06-06-2002 09:08 PM
