Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 06-03-2011, 04:03 PM
r82148v r82148v is offline
2002 Mazda Protege5 - OBDII communication failure
Hey all..
I have a 2002 Mazda Protege 5.
I failed NJ state inspection for OBDII communication failure.
I checked the power pin (16). It was good with 12+
I checked pin (4) being the main ground and pin (5) being the signal ground.They are good too.
I tried disconnecting the battery for a while. That didn't help.
I checked every fuse I could find in the engine compartment and under the driver side dash with a volt meter. All is good.
The car runs perfect with no engine light on.
I have a simple OBD II scanner that keeps coming up ERR with KOEoff and with KOEon..
I tried using the scanner on a toyota and the scanner worked fine..
Would anyone have a solution as to what I can troubleshoot?
I read somewhere on the internet that a 2002 Mazda can either be OBDII or CAN....
Just for reference, the pins on the connector have wires in 4,5,7, 13 & 16
Thanks
Rick
Old 10-13-2014, 09:59 AM
mikeg609 mikeg609 is offline
the same is happening to me but I got 2 lights on, In the dashboard they are ABS and E-BRAKE lights on, whenever the ABS light turn off the E-brake trun off too. helllllpppp..... please....
2003 Mazda Protege5 - 9,200 mi - Auto, ABS, Side Air Bags zoomer11 Cars/Parts for Sale/Exchange 0 06-13-2005 12:38 PM
Mazda Protege5 Engine Code simplistek 323/Protegé/Familia/Etude/Allegro 0 08-11-2003 08:48 PM
Mazda Protege5 Sound Gorillaz Graphic Manipulation 10 02-05-2003 06:06 AM
Nissan Sentra SE-R vs. Mazda Protege5 Jay! Car Comparisons 3 05-30-2001 11:48 PM
