Go Back   Automotive Forums Car Chat > Fabrication & Tools > General Tools
General Tools Discussions about tools - there are thousands of various tools you can use to work on your car. Do you have the right one for the job?
Old 06-02-2011, 11:27 AM
NetDriver NetDriver is offline
Snap Ring Pliers
Hello to everyone!
I need a tool to remove a type of Circlip or Snap ring that is not like the more common thin snap ring with 2 holes one each end into which you insert one of the prongs of the common snap ring pliers. These retaining rings are thicker, heavier, stronger and the ends come to a tapered point, rather than having holes to use for installation & removal [Please refer to pics]. I am having difficulty removing these rings from this transmission and I may need to re-use these rings, since this is an older trans and I have not been able to find new ones available yet.
There is apparently a specific type of Snap Ring Pliers used to remove this type of Circlip. I only have the type of tool that uses 2 points that are inserted into the holes in the snap ring. I have been told that there is a different type of tool needed for these rings, but I have not been able to find anything like this shown on any of the websites I have been searching.
Does anyone know of the type of tool I need to remove these type of rings without damaging them, and who makes them or where I can find these tools? Any suggestions or advice will be very much welcomed!
Jay
Old 06-02-2011, 08:13 PM
snshddog snshddog is offline
Re: Snap Ring Pliers
There is a tool for that type of ring, the snap on number is SRP4. Many stores sell a cheaper version but i give the number so you can look it up and know what they look like. Without the right tool you will dammage the clip.
The Following User Says Thank You to snshddog For This Useful Post:
NetDriver (06-03-2011)
Old 06-03-2011, 08:05 AM
snshddog,
Thanks much! That was just the tip I needed to get me pointed in the right direction!
Jay
f***ing snap ring HeatherW Camaro Discussions 1 08-27-2004 07:16 PM
peice of snap ring? found in transmission pan rick53172 Dakota 0 08-04-2004 11:35 AM
Steering Wheel Snap Ring Removal mightymouse68 General Discussion 1 07-01-2004 08:31 PM
FS JDM bb6 Pistons with snap rings and wrist pin pikkagtr Engineering/ Technical 1 02-16-2004 05:35 AM
Tags
circlips , pliers , ring , rings , snap
