Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 06-01-2011, 12:31 PM
mnrumpole mnrumpole is offline
Send a message via Yahoo to mnrumpole
Unhappy fuel pump/sender help
original post below, Now, I find out there are baffles inside tank that are loose and maybe stopping gas flow. Is there a way to take all the baffles out; or get a small tank to just get me thru. I have limited income and this old caddy still does not burn oil and get 25+mpg, thanks.
I have a 92 deville 4.9 liter; the car continually stalls/hesitates\won't start, unless I hit the bottom of the fuel tank. Is there a way I can install a fuel pump and sending unit that is NOT in the tank? And, what are the codes that will tell me if the pump or sender, etc. is bad. thanks
Old 06-01-2011, 07:05 PM
maxwedge maxwedge is offline
A990 racer
Re: fuel pump/sender help
In 92 there are no codes for the fuel pump failure. I do not beleeve what you suggest will work as you would, without running a straight pipe into the tank, be able to use an external pump.
The Following User Says Thank You to maxwedge For This Useful Post:
mnrumpole (06-07-2011)
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 10:42 AM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-04-2009 11:39 PM
Fuel pump problem lmattiso Rodeo | Passport | MU 0 04-25-2009 02:08 PM
Help with Fuel Pump Resister Relay bbaker1985 Grand Prix 1 03-28-2009 09:14 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 08:04 AM
