Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 05-31-2011, 04:15 PM
Smaje Smaje is offline
87thunderbird problems starting
I've got a 87 Thunderbird V8 5.1ltr. Lately I've been having problems with the car, when the car sat for a while it would start fine, but starting it again after driving (like going to the grocery store) it would start, and then once it would idle down turn off. If I would sit there long enough with my foot on the gas, eventually when it idled down it wouldn't turn off. The problem has gotten progressively worse to where a couple days ago sometimes it wouldn't even turn over. Driving it today for the first time today (its 95degrees out) The car started fine, but every time it would go to a stop it would stall. Any help is much appreciated, thank you in advance.
Old 06-01-2011, 06:24 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: 87thunderbird problems starting
Welcome to the forum Smaje. It sounds like you need to clean or replace the IAC. Remove the negative cable from the battery (being careful not to touch the positive terminal with the wrench while loosening the nut) and then remove the connector from the IAC. Remove the two bolts holding the IAC and you can remove and clean it. Spray electrical parts cleaner (tuner cleaner) into the two passages until the cleaner running out of it is clear. Also spray into where the IAC bolts too. If you have an air compressor handy, blow air lightly into all passages to dry out the cleaner. After the tuner cleaner has dried, reassemble in the reverse order. If you don't know what the IAC looks like then enter your car's info into the Autozone website and then in the upper right where is says Product search enter IAC. Hopefully cleaning it will solve your problem and doesn't cost much.
The Original 97Bird
The Following User Says Thank You to 97Bird For This Useful Post:
Smaje (06-13-2011)
Old 06-04-2011, 05:50 PM
Thank you 97bird for your response. I went ahead and replaced the IAC, and sprayed cleaner. It seems to be idling a bit better, but it still cuts off, it idles up and down like its trying trying to idle correctly but just ends up cutting off. So pretty much the same thing as before, just not as bad. Any other ideas? Thank you again
Old 06-05-2011, 03:42 PM
97Bird's Avatar
Did you buy an aftermarket IAC? I've heard of people having problems with IAC's from Autozone.
The Original 97Bird
Old 06-13-2011, 12:10 PM
Thankyou 97bird. That's what it was. I guess with some parts you need to get the manufacturers.
Old 06-13-2011, 06:27 PM
97Bird's Avatar
Glad to hear you got it fixed. Where did you buy the IAC that you had a problem with?
The Original 97Bird
Old 06-16-2011, 04:14 PM
Bought the IAC from Autozone.
Problem starting latorawilson Impala | Impala SS 8 04-29-2011 03:14 PM
98 Cherokee Starting Problems cdmonday Cherokee 4 01-22-2010 11:13 AM
98 Cherokee Starting Problems cdmonday Cherokee 1 01-21-2010 07:08 AM
Originally a Radiator Fan Problem, Now Car Won't Start fiskee '91 - '96 2 09-09-2009 12:17 PM
94' k1500 starting/electrical problem k150094 C/K 0 08-21-2009 10:47 PM
