Old 05-31-2011, 02:32 PM
ken_m ken_m is offline
96 PAU intake manifold gasket replacement
96 PAU with an intake manifold gasket leak. How do I replace all gaskets associated with the manifold? If you can supply pictures of the lower gasket, I'd appreciate it. I saw a thread about the gasket replacement but couldn't find how to replace it or exactly where the lower gasket is.
Old 05-31-2011, 04:52 PM
enslow enslow is offline
Re: 96 PAU intake manifold gasket replacement
Check the following:
http://www.automotiveforums.com/vbul...lay.php?f=2144
BNaylor seems to have a lot of experience and knowledge, you can't go wrong with his advice.
A couple of other forums have dedicated tech sections with detailed instructions. They're not hard to come by using google.
Old 06-02-2011, 05:55 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
When replacing the gaskets on an '96 Ultra (Series II Vin-I) you should replace the following:
FEL-PRO Part # MS95977
1st Design; w/Rubber end seals w/o Locating pins; Lower set
FEL-PRO Part # MS95744
Plenum Gasket Set; Upper set
FEL-PRO Part # 61024
Throttle Body Gasket
ACDELCO Part # 217454 or STANDARD MOTOR PRODUCTS Part # SK9
SEAL KIT,F/INJR(O RING
99 Windstar 3.8L Replacing Intake Manifold Gaskets dariem Windstar 8 03-21-2015 05:22 PM
Intake Manifold Gasket End Seals bjaymo3 Grand Prix 5 07-30-2010 08:29 AM
Replace Intake Manifold Gasket Stammtra Cougar 4 07-20-2010 12:13 AM
Intake manifold gasket replacement question... smaggard C/K 2 06-10-2004 07:24 AM
5.7L misfire after intake manifold gaskets replaced AKGMC Sierra 0 11-21-2003 11:58 PM
Tags
gasket , manifold , pau
