Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 05-30-2011, 11:45 PM
carpenter_jai's Avatar
carpenter_jai carpenter_jai is offline
AF Stunt Driver
Alternative tire sizes
Hi,
My original rims have my winter tires mounted on them. I would really like to own a second set of rims for summer tires. I drive a 2WD 1990 Toyota Pickup ext cab, 6 foot bed.
What I want to know is: are there any 14, 15 or 16 inch rims out there that fit my lug pattern?
Also, If I were to switch from the stock 195 75r14 to 215 55r16 for example, what changes are there in handling or wheel weight? I already checked that the non stock example is less than 1 percent smaller than stock, so overall wheel well space and speedometer not much affected.
Cheers,
Jai
96 3 cylinder Geo Metro (currently being rebuilt)
Old 05-31-2011, 09:13 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: Alternative tire sizes
The 2WD bolt pattern is 5 x 4.5", same as Jeeps, 2WD Nissan trucks, and others I can't think of right now.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 06-01-2011, 04:08 AM
AF Stunt Driver
Thanks fourwd1. i used that info to search for this linkhttp://www.therangerstation.com/tech...l_fitment.html There's good info here and a list of other 5:4.5 bolt pattern vehicles.
I wouldn't want to make a rookie mistake because I "thought" I knew what I was doing by changing tire size. I don't need bigger tires, just more common tires so I can take advantage of used tire sales.
Thanks,
Jai
Old 06-03-2011, 10:10 PM
fourwd1's Avatar
AF -Advisor
In addition to the bolt pattern, you have to consider the offset and backspacing as well.
89 4Runner - stock
Tire pressure affect on tire size SPLThunder Engineering/ Technical 10 02-17-2008 04:30 PM
Tire size, rim size, how big is your limit? krackaboy1 Nova 0 05-01-2006 08:57 PM
