Go Back   Automotive Forums Car Chat > Jeep > General Discussion
Old 05-30-2011, 08:41 PM
dylanborns dylanborns is offline
Can a bad water pump affect power steering
Hello. I've been dealing with an issue with my Jeep for the past few weeks, and I'm at a loss. It has an AMC 360 motor in it, unknown year. I started hearing louder than normal squealing coming from the motor, but it was intermittent, and would stop pretty quickly. Then that became more frequent, and louder. At the same time, I was noticing some erratic wandering in the front steering, and intermittent loss of power steering. Then one morning, I had no power steering at all.
I checked the fluids, and it was full. I thought maybe air got into the system, so I bled it and that didn't help. The PS would be normal one minute, then totally go out the next, and I was still having the squealing issue. So I'm thinking the PS pump is going bad, and I changed that out. Filled and bled the system. Still intermittent ps loss.
The only other pump I have on the motor is the water pump, and I've noticed more than normal amounts of coolant puddled on the top, side and under the vehicle. After some research, I've learned that if a water pump is going bad, it will leak at a weep hole. So I'm convinced its the water pump.
So after all that, my question. If the water pump and ps pump are run by the same belt, and the water pump is going bad, can it affect the ps pump, (or other items on the same belt)? I've looked at the water pump pulley while its squealing, and it doesn't look like its freezing up or anything. My other thought is if coolant is being thrown on the belts/ pulleys, the ps pump could be slipping maybe? I don't know. Any help is appreciated.
Thanks
Dylan
Old 05-30-2011, 08:51 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Can a bad water pump affect power steering
Your problem is certainly related to the water pump. The leak is getting onto the belt and causing it to slip and thus the power steering does not work. Change the water pump and put on a new belt. Do not reuse the old one due to coolant contamination.
The Following User Says Thank You to GTP Dad For This Useful Post:
dylanborns (05-30-2011)
Old 05-30-2011, 08:53 PM
Hey GTP, thanks for the fast reply. I was hoping that was the issue because the next step would be to replace the steering gear.....$$$. I'll try the new pump and a new belt also.
Thanks again!
Power steering flush Windstar 98 - No place to work serge_saati Windstar 9 11-05-2015 08:02 PM
Problems with Acceleration and now Power Steering dbhynds '01-'05 Civic 5 01-06-2010 07:41 AM
Cutlass Supreme - which power steering fluid serge_saati Cutlass Series 1 12-07-2009 07:15 AM
92 Cutlass Supreme Power Steering Hose Mikey_G Cutlass Series 4 11-23-2009 01:47 PM
2000 PA Power Steering Fluid Check buickultra2000 Park Avenue 2 11-12-2009 10:12 AM
