Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 05-29-2011, 02:55 PM
lootzy lootzy is offline
1999 crwn vic with 4.6 coil on plug
I hope sum1 can help, this by reading is a common problem i need a intake maifold (dorman) is the only aftermarket i can find, i have the 4.6 ltr engine with coil on plug. does anyone have a part #. for the correct app.
how about removing them darn fuel lines i accidently rubbed with plyers and in need of a new front fuel line there are 2 front and back of fuel rail, wt heck they wont come apart?
Old 05-31-2011, 07:44 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 1999 crwn vic with 4.6 coil on plug
I'm not sure of the Dorman part number, but just make sure you get the "NPI" or "Non Performance Improved" model. The PI model can be used but requires modification of other parts. The Dorman NPI intake is a drop in direct replacement. Most people I talk to just buy them from eBay.
As for the fuel rails, there are special tools to remove them. To do the intake swap, you don't have to remove them, just lay the fuel rail off to the side.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Need help with 4.7L -2000 dak McCowan Dakota 1 11-08-2010 11:15 AM
f150 4.6 overheating JoeB64 F Series 3 02-06-2010 09:29 PM
4.6 from Crown Vic to F150 bigj-dog F Series 5 02-02-2007 09:01 AM
did lightings come out with 4.6 EugeneLaforge Crown Victoria 2 03-13-2006 06:42 PM
94 crwn. vic. tatto57 Crown Victoria 2 07-31-2005 03:48 PM
