Old 05-28-2011, 10:17 PM
bbaca bbaca is offline
please help me!!!
i have a 2000 pontiac grand prix gtp and every time i start it, it will start puttering but it will drive a lil wile then it will die after bout 5 min at the most its blowing black smoke out the tail pipes and its smoking under the hood does any body have any suggestions about what it could be
Old 05-29-2011, 09:47 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: please help me!!!
Welcome to AF!!
The first place to start is with the catalytic convertor. It may be blocking up and causing the car to stall. The rich condition you currently have has damaged it and that would cause the car to stall. However, the rich condition will need to be corrected before you do anything else.
You obviously have a rich condition given the fact that the you are blowing black smoke out the tail pipe. You may have a stuck injector, bad plugs, dirty air filter that is restricting air flow, a dirty Idle air control motor, bad Mass Airflow Sensor (MAF) and a host of other issues.
I would start by pulling the plugs to see what they look like. If you find wet plugs or plugs that are covered with carbon that indicates incomplete combustion and I would start looking for an issue with the fuel delivery system. Changing plugs alone may help the issue. Once the plugs are changed check the fuel pressure to make sure it is good. This should be done with the key off and with the key on. This way you can find out whether the injectors are holding pressure.
Since the car is stalling as you indicated there are a couple of possible causes. First unplug the MAF sensor and see if the car stalls out, it may even run better if the sensor is bad. If there is no change you may have an issue with the crank position sensor being bad and causing a stalling issue.
One thing you didn't say is whether you have a check engine light. If you do have the car scanned to see if there are any codes. This will give you some indication of where the problem may be.
I hope this helps as it is hard to tell you everything to check in a forum post. If this doesn't help you find the problem post again and we can try some other things.
Please help me.....oh please please pleas jak skrill USA 0 07-03-2010 07:51 PM
help me please help me f22 swap jaysspeed Accord/TSX/Accord Hybrid 1 07-14-2004 08:51 AM
Please help me fix my Jeep so my girlfriend won't make me sell it! HeXploiT Cherokee 19 05-02-2004 10:30 PM
Please Help Me Please getfast Off-Topic 7 07-15-2003 04:46 PM
Please Help Me Choose A Body Kit!! The Last Post Was Wrong Click This One And Help Me inhaledeep Integra 3 03-22-2003 02:28 AM
