Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 05-28-2011, 06:04 PM
gjones11 gjones11 is offline
1998 2.2 sounds like a diesel
1998 Camry sounds like a diesel and poor engine performance. The valves are rattling and when cranking the engine is hard to start. I think the timing has jumped a couple of teeth and that is what is causing all of the problems. Engine has about 150,000 miles and I have no ideal when the timimg belt was last changed. Your thoughts please.
Thank you,
Greg
Old 05-29-2011, 04:34 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 1998 2.2 sounds like a diesel
You may be right. I would change the timing belt as soon as possible.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
The Following User Says Thank You to Brian R. For This Useful Post:
gjones11 (05-30-2011)
Old 05-29-2011, 07:36 PM
artbuc artbuc is offline
Thank you,
Greg
Is that an interference engine? Hope not!
Old 05-29-2011, 08:16 PM
Brian R.'s Avatar
Resident Chemist
No, it's not. If it was, it would just lock up if the valve timing were off by too much.
Old 05-30-2011, 06:14 AM
It's not an interference engine, checked that first.
Greg
Old 05-30-2011, 06:20 AM
Well, after further inspection, the timing belt is in good shape and does not seem to have skip a tooth or anything. Cranked the engine with the timing cover off and all seems fine there, but the engine is toast. After talking with my son and putting more of the story together, it would appear that he ran the car way to low on oil and told me that he heard it start ticking (in his words) and then stop to put oil in. He said it never stopped and seemed to get worse after that. Damage already done I suspect, so it's decission time as to the fate of the car, I am thinking it's going to make someone a good parts car as the rest of the car is almost perfect. Thanks to all, Greg
1997 Chevy S10 2.2 Starts Then Dies Logan76 S-10 9 07-29-2010 03:44 PM
no start 95 cavalier 2.2 jeffyweasel Cavalier Problem Diagnosis 2 03-14-2009 06:12 PM
2000 JGC (4.7L) Gas Engine Sounds Like Diesel... tStar Grand Cherokee | Grand Cherokee SRT8 3 09-23-2008 09:26 PM
Does anyone know what a 2.8L sounds like dualed out redhoss S-10 3 06-15-2006 04:15 PM
Rattling Sound Coming from middle of engine! Sounds like DIESEL,Advice needed please! Donald91tbird Thunderbird 12 12-07-2004 03:07 AM
