Old 05-28-2011, 08:59 AM
kennycu kennycu is offline
92 ultra power steeering hose
There's a power steering hose on the supercharged engine that goes across the front of the engine. This hose has gotten a leak from it rusting. It's some kind of "cooling pipe" that is listed in a bonneville manual as "steering gear outlet hose" . I don't see a replacement from the usual places.
Is this high pressure or low pressure? If it's now available, can I put on some kind of PS cooler to replace this hose? Wonder why they used a cooler on non-supercharged motors and this pipe on the SC?!
Thanks for any input.
KennyC
Old 06-02-2011, 05:22 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 92 ultra power steeering hose
The supply & return hose are both available @ RockAuto Parts Catalog
Power Steering Return
Power Steering Pressure
Old 06-02-2011, 10:01 AM
Well, I was confused by the picture and the description saying "with cooler". The "cooler" on the SC Park Ave is just an extended metal hose on the cradle at the front of the engine. The non-SC has the more common radiator type cooler. Hopefully just a generic pic of a PS hose because it doesn't look like what I need. I ordered it and we'll see.
Thanks for the reply HotZ. Even though this was an easy one for you, I have used your valuable advice on this forum countless times.
KennyC
Power Steering hose/Pressure Hose burijon Intrigue 6 11-30-2018 11:18 AM
92 Cutlass Supreme Power Steering Hose Mikey_G Cutlass Series 4 11-23-2009 01:47 PM
2000 PA Power Steering Fluid Check buickultra2000 Park Avenue 2 11-12-2009 10:12 AM
Power Steeering Noise terence123cars Windstar 3 02-07-2006 09:44 AM
Power steeering problems mikeypooh1 Eclipse Problem Diagnosis 2 01-04-2005 08:39 PM
