Old 05-26-2011, 02:12 AM
Marianitem's Avatar
Marianitem Marianitem is offline
1993 Nissan Skyline GT-R r33
This one is a Fujimi curbside kit for the GT-R r33, the first one of my GT-R history collection Iīm building. I chose my favorite color for this one: an atempt of "Midnight Purple". More on later.
Kit overall is OK, with almost no fitting issues. Front left roof pillar came a little bent. Front bumper link to sprue was located at a very bad position, making it difficult to cut without damage, but as it was my fault for being anxious, i did not want to fix it too much, just to keep it as a reminder. Also many links to the sprue are really big so you have to work a lot after removing from them. I donīt have many pics of this work, as I met this forum after a lot of work on this one.
Iīve finished a poorly build of the interior, which I think Iīll be re-painting and adding floor mats, fur to door panels and stuff, just to match the body finish.
Iīve already gave the body about 7 ABīed enamel coats. Just to mention the last 4 they were 2 base coats of enamel purple with a bit of silver, and the last 2 were a mix of Humbrol #68 purple with Humbrol #52 metallic baltic blue on turpentine. I love the color that I got from this final coat so Iīll not be spraying any more color on this one.
Please look at the texture of the paint. It is not as grainy as I usually get it, but I canīt sand it due to metallic paint. I also have a few dust particles, maybe not really noticeable. Should I apply many mist coats of clear so I can sand and polish? I cannot risk rubbing thru clear as it will ruin the color. Iīm sure I wouņd throu it thru the window if that happens as Iīve already done too much on this body to get the right color.
For the same reason, should I use acrylic X22 clear or Humbrol clear gloss cote enamel? Acrylic seems more user friendly, but maybe too soft to polish safely, and enamel takes a lifetime to dry and it always stays sticky. Iīm afraid wetsanding a sticky surface should never be a good idea. I also have RustOleum Laquer spraycan, but I was told not to apply over enamel.
Also, would it help the drying process to keep the clear-sprayed body in a box with holes near a dry-heat source? Would that shorten the drying time, or solve the "always sticky" issue?
Thx in advance for any tips/comments.
Old 05-27-2011, 09:30 PM
Marianitem's Avatar
Re: 1993 Nissan Skyline GT-R r33
To the moderator: I accidentaly opened this thread here instead of "WIP - Street". Would be great if you can move it, or let me know if I have to re-post (please donīt clean it in that case). Thx
Old 05-29-2011, 03:34 AM
Chieflongshin Chieflongshin is offline
That colour looks familiar....
This was my first model too before trying a 32 and 34. Good luck and enjoy building.I found with the R33 the colour was hard to do also and i struggled with the sanding back processes. There are some really good tutorials on here about sanding back. ( Have a look for a recent WIP about a porsche 924. Thats very good!)
Sorry for the slight hijack
Old 05-29-2011, 10:27 AM
Marianitem's Avatar
Nice addition to my thread XD. Is that 33 the white box Fujimi kit? That makes me think of lowering it a bit.
C'mon, you also built the silver z-tune? At least my 32 it's gonna be gun metal I will check on the 924, thx.
As there is to much metallic paint here I will clear it as it is with many mist coats. Then I will have to sand back a lot, but don't want to risk the color.
Old 05-29-2011, 12:00 PM
Yeah I built all three of them. The z tune was the last one as i began to get a little better at it again.
The 33 is a tamiya kit, went together very nicely.
Old 05-30-2011, 02:06 PM
Marianitem's Avatar
What kind of finishing process did you use on each of them? I mean color/polishing, or color/clear/polishing, or color/clear, or well, other.
The color looks quite the same. What did you use?
Old 05-30-2011, 02:48 PM
I think for the purple one i just used a tamiya purple and lightened it out with a metallic silver.
In regards to my painting process i'm a big time learner on this. That purple skyline was a straight prime and paint with no clear or polish.
As i worked through to the ztune i was priming, painting, clearing and then doing a little buff of the colour.
I'm trying to get my head around the wet sanding and that as of late with recent models.
Still learning...
Old 05-30-2011, 08:24 PM
luchoteam's Avatar
luchoteam luchoteam is offline
Nice work marian!! suscribed to see more news
Old 06-29-2011, 12:56 PM
Any updates on this one?
Old 06-29-2011, 11:16 PM
Marianitem's Avatar
Not much really, as I had too much time at work. Here goes some info for the fans :P
I gave it 4 mist coats of clear using RUST OLEUMīs LAQUER. Yeah, that crappy rattle can can be used safely over enamel. I made a "spoon test" and nothing bad happened so I gave it a try on the body. Anyway I still have to give it a couple more before I start polishing. I really want to have the paint coat protected as there are many metallic components and different tones of colour on each layer. I CANNOT rub thru on this one. I polished the upper rear wing and it looks fantastic, so I expect to have the whole body looking good.
I also considered redoing the interior/chassis as now it looks too simple compared to the work on the body. Some extra ABing, floor mats, seatbelts, not big deal. I really lack of time right now.
Pics as soon as I polish.
Visit my "Completed project" threads:
http://www.automotiveforums.com/vbul...archid=4238051
2002 Nismo R34 GT-R Z-Tune "PS2 Gran Turismo version"
1989 Nissan Skyline GT-R R32
1989 Nissan Fairlady Z 300zx (z32)
1993 Honda Civic FnF
Old 06-30-2011, 02:06 AM
I know feeling with time. Had to post though as i love the skyline builds, just purchased a mcr racing ( i think it is off top of my head ) skyline r34 and a veilside r32 which should look a little like this i believe.
Old 06-30-2011, 09:25 PM
Marianitem's Avatar
Both will look great! I really like that 32, but doesnīt look like the Veilside kit I know.
I was trying to use polishing sticks on my R33. I thought that 4 mist coats of clear were enough not to rub thru. I was wrong. Now I have to start OVER AGAIN. Iīm really dissapointed...
Old 07-01-2011, 02:02 AM
You are totally right. I'm being thick, its this one but i was using the blue as a colour inspiration.
http://carmodelingcorner.com/BuiltKi...ine_Combat.htm
Old 08-05-2011, 03:56 PM
Marianitem's Avatar
As I rubbed thru the clear in some minor spots, the metallic finish turned out weird, unacceptable. I decided to give this one another shot of paint over the clear, to fix those spots and to try a new mix. Itīs been an hour since the spray and no problems so far. Iīve used a 3:2 mix of Humbrol 52 Metallic Baltic Blue + Humbrol 51 Metallic Sunset Red, thinned to +-33% with turpentine and high air pressure. BTW, it was sprayed over RustOleumīs Laquer.
Here are the results of the spray:
The little dusty bits are really loose, and some of them were easily removed. I have faith on this one
Iīm loving the color. It looks much better than the previous one, less toyish, more serious. Pics were taken with a 5mp Milestone 2 camera, so they donīt make justice to the real thing. Anyway, they give you an idea of what is looking like. I will leave it for a couple of days on the open air hoping that it helps the curing process. Then I will store it somewhere and forget about it for a month. Finally it will be clear coated thick to make sure this color coat doesnīt suffer any more. I donīt really want to see any more purple paint for a couple of months (Iīve been painting this one for more than a year with troubles, and my stupidity as a catalyst).
There are some little flaws, even some molding lines, but I started this project long before knowing AF so many mistakes were made on the first steps. Anyway I just want to finish it and step up.
This was meant to be a quick build so the interior and chassis will be really simple, instructions-like. I learned a lot since I started this one, but I will just fix some paint issues on the interior and keep it simple. As soon as I get the retouched interior Iīll post some pics.
C&C welcome. Thx for looking.
Old 09-01-2011, 12:39 AM
Marianitem's Avatar
Quick update:
I retouched the interior paint with a new shade of grey, ABīed (it was brushpainted before with an ugly military green-grey). Added seatbelt buckets, and will add belts as I install the windowīs clear part.
And a little mockup of what it looks like today.
Itīs a pitty that Fujimi didnīt make bigger "inner wheel well".
Body will be cleared this week/weekend and will have to wait several days to be polished. Once cleared and black trimmed Iīll see if I lower the suspension a bit. I donīt like the actual stance
Decals and metal transfer logos will be added after polishing the clear.
Thx for following and comments, and sorry for the cell pics. Itīs 2:30 AM and I donīt have the camera batteries charged
Nissan Skyline GT-R R33 S-Tune 73superduty Completed Projects / Gallery 5 01-27-2010 07:52 AM
AutomotiveForums.com R34 Nissan Skyline GT-R N1 RACECAR for sale on eBay igor@af General Discussion 0 04-10-2009 03:43 AM
Duke Racing Nissan Skyline GT-R R33 - Turbo and High Tech Performance Magazine Automotive News Automotive News Desk 0 07-24-2006 11:10 PM
WTB/WTT: Nissan Skyline GT-R R33 Model Vash Cloud General Discussion 7 06-23-2006 11:39 PM
Nismo Nissan Skyline GT-R R33 400R Patrick-T. Car Modeling 4 01-30-2003 05:05 PM
