Old 05-21-2011, 02:54 PM
AlphaCrow AlphaCrow is offline
To fix or not to fix
2000 blzr, 2WD, 4Dr, V6, 160k miles. Small oil leak from rear main area. I've never been able to determine where exactly it's coming from, it leaks so slow. It doesn't drip at all, never. I just see oil smeared backwards from that area on the underside. It's been that way since I got it in 2002. I'm a dirtbag for not doing anything about it, I know It never drops the oil level below "normal" between oil changes. I use high mileage oil to maybe soften the seals, but no luck. Question: Should I bother with it at this point? I generally keep up the maintenance on it.
Old 05-21-2011, 02:58 PM
inafogg inafogg is offline
Re: To fix or not to fix
IMO i would'nt
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
The Following User Says Thank You to inafogg For This Useful Post:
AlphaCrow (05-21-2011)
Check engine light problems fixed, not fixed? MrMet6986 Elantra | Avante 2 02-10-2009 08:26 AM
Need advice - tanny shudder not fixed by fluid change cleveman Windstar 19 09-30-2007 08:50 PM
98 jimmy trouble code PO404, replaced EGR, still not fixed sggriffey Problem Diagnosis 3 09-18-2007 04:37 PM
67 F-100 Battery not staying charged new alternator not fixing it. BarneyGeo F Series 6 04-11-2006 02:03 PM
1994 Buick starting problem $$$ and not fixed! acrufoxie LeSabre 7 11-20-2004 05:09 PM
