Old 05-21-2011, 04:59 AM
jallyscott jallyscott is offline
Car wash using pressure washer!
Hi, I’m exploring using a pressure washer from karcher to wash cars. I understand that one can attach a foam lance to it so that it can dispense detergent. Would washing a car this way without the use of any mitts be clean?
Essentially, I use the high pressure spray nozzle to wash off dirt, and then attach the foam / soap lance followed by another final spray down via the pressure washer.
Appreciate any thought from enthusiast who may have tried this technique.
Thanks in advance!
Old 05-21-2011, 10:30 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Car wash using pressure washer!
If you're really trying to get the car clean, this is not a good way to do it. For starters, using high pressure on dirty paint will force dirt particles in to the clear coat/paint and may cause more damage than if you just left the car dirty. There will often be grime on the vehicle that will require more agitation than high pressure rinsing to remove.
If you're talking a typical car or truck, my suggestion would be to just use a garden hose with an adjustable nozzle set to "Shower" to moisten the paint finish. Then use a good automotive car wash soap to sponge down the car and remove the dirt, followed by a final rinse. The "Shower" setting should be fine for the final rinse as well.
If you're talking a large RV or tractor/trailer, then you may be limited to something like a power washer to get all the surfaces wet.
-Rod
Old 05-21-2011, 11:44 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
I have a 3000 psi gas pressure washer, and it won't get things truly clean. The dirt on the car is kinda an oily road film. Won't come off with pressure washers without taking the paint off with it
Hand washing is the only way.
Dragging people kicking and screaming into the enlightenment.
Old 05-23-2011, 02:37 AM
Bartelot Bartelot is offline
It’s good to use pressure washer to clean your car but don’t use high pressure spray nozzle because it could scratch and take off paint. Always try to spray from some distance.
Hope this will help you.
Last edited by shorod; 06-04-2011 at 09:32 PM. Reason: Non-relevant spam-like link removed by moderator.
Old 06-04-2011, 12:25 AM
carpenter_jai's Avatar
carpenter_jai carpenter_jai is offline
AF Stunt Driver
If you want to spend money on a helpful gadget you need a mobile filter setup for the final rinse. Water from a filter system gets the water truly pure and will not leave traces of hard minerals after the rinse water dries. I learned this from my neighbour who washes windows professionally.
Jai
96 3 cylinder Geo Metro (currently being rebuilt)
Old 08-20-2011, 05:00 AM
Rick32 Rick32 is offline
Hand-washing a car is too difficult for lazy people like me... I bought a pressure washer a year ago and use a really simple technique for car cleaning:
1. Rinse the vehicle completely before washing
2. Soap your car. Start from the bottom and work to the top. You do not want to spray the dirt from the lower parts on .
3. Let the detergent work for 5 to 10 minites.
4. Rinse the car completely. This time work from the top to the bottom. Do not spray too close to remove a stain - you will scratch the paint.
5. Towel dry. A lot of people omit that step. Wrong!
Always make sure you towel dry your car after pressure washing. It eliminates the ugly dirty stains left when water evaporates. When a towel gets dirty, just refold it to a clean side.
Do not be tempted to buy too powerful pressure washer just for car / garage cleaning. Unit up to 2000 PSI is completely enough. My pressure washer is AR390 - it is a small, 1800 PSI unit, but is just what I need to clean around the house.
Hope that helps. Now go and get yourself a cold beer! Cheers!
Do you use automatic car washes? Gojirr Cars in General 5 02-01-2011 11:03 PM
waterless car wash veron Cars in General 0 03-04-2010 11:31 PM
(eBook) Buying New and Used Car Tips schumi_reloaded Car Buying Q&A 2 06-05-2009 11:18 AM
