Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 05-20-2011, 05:59 PM
moby1154 moby1154 is offline
1998 Monte Carlo Fan wont turn on with A/C
I have a 1998 Monte Carlo with 3800. My cooling fan wont cut on with air condition. The a/c compressor is coming on and the cooling fan for the engine cooling. No fan for a/c so my air condition is not working. Could someone please help. Thanks alot, well appreciated..
Old 05-20-2011, 09:19 PM
maxwedge maxwedge is offline
A990 racer
Re: 1998 Monte Carlo Fan wont turn on with A/C
If the ac compressor comes on and there is freon in the system then you should get cooling initially without any fan operation.
The Following User Says Thank You to maxwedge For This Useful Post:
moby1154 (05-20-2011)
Old 05-20-2011, 10:13 PM
brcidd's Avatar
brcidd brcidd is offline
I'm going to assume by "Fan" you mean blower motor- the one inside the car-- so beat on it, if it comes on- replace it- it is worn out, other than that does it works on any speeds? Try "cutting" it on and off a few time.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 05-20-2011, 10:28 PM
Thanks for the info. I mean the cooling fan in front of the radiator. Its has two but no when the compressor comes on the 2nd one dont come on anymore. The a/c is not getting cold. The compressor is coming on. Just happened all of a sudden.
Old 05-21-2011, 08:21 AM
brcidd's Avatar
"W" cars (as is yours) wait for 175psi discharge pressure to engage the fan- if your compressor is "cycling" it is because your cooling fan is inop- and compressor is shutting off due to high discharge pressure.
Your Variable stroke compressor can run with as little as 5 ounces (system spec is 32 onces) of refrigerant in it- won't cool, but will engage---so my guess from here (knowing 65% of a/c failures are due to loss of refrigerant) is that you have lost enough refrigerant to not cool and not be able to generate 175 psi discharge pressure.
does it cool while driving? probably not. I say your cooling fans are fine, the system is just not activating them- due to a/c leak.
Find and fix your leak, recharge, and watch what cooling fans do.
'99 GMC Yukon
Old 05-28-2011, 03:48 PM
Thanks for everyones help, it needs the compressor replaced. I filled it with freon and its throwing the compressor oil out and the freon. I ordered one so wont be too bad to put on. Thanks for all your help. Have a happy memorial day weekend.
96 Monte Carlo Ls with HORRIBLE NOISE RegginRegulator Monte Carlo 1 01-23-2011 02:22 AM
turn signal issues on 2003 monte carlo bob697 Monte Carlo 2 10-27-2010 10:28 PM
1998 Monte Dash Lights Will No Longer Work... ermiller79 Monte Carlo 0 12-08-2009 08:35 AM
2000 monte carlo random wont start, turns off while driving jkayes Monte Carlo 5 11-12-2007 04:04 PM
1998 Chrysler T&C minivan both cooling fans wont turn off waltham41 Caravan | Voyager 11 08-05-2007 08:44 PM
Tags
air , carlo , condition , monte
