Old 05-28-2003, 08:43 PM
funkdaflex1 funkdaflex1 is offline
b18 head on what bottum end?
hey i can get a b18 ls non vtec head from my budy and i want to know what kind of bottum end should i get i know a guy sellin a b16 bottum end. how well would that work out? its goin to be turbocharged to so if the compression ratio is goin to be different with different bottom ends does n e one know what it would be and this swap is going into a civic
SOLD
V
D16y8-
-Greddy Turbocharger
-Greddy front mount intercooler
-Greddy type S BOV
-Greddy profec E-01 boost control
-Apexi N1 cat back exhaust
-Tokico Hp shocks
-Eiboch Sportline springs
-AEM cam gear
-MSD spark plug wires
-Walbro 255 fuel pump
-DC sports front upper strut bar
-B&M fuel pressure regulator
-B&M fuel psi gauge
-Tenzo R Pasion 5 17" white
-Hankooks ventus hr2 tires
-eclipse and mtx speakers
-Alpine CDA-7893
-Alpine XM radio module
Old 05-28-2003, 08:53 PM
kittedb18bt's Avatar
kittedb18bt kittedb18bt is offline
well i have never seen anyone do that. tell us if it turns out (if this is the route u choose to go). the b18b head and block work very well for turbo apps. hope u get the ls tranny too: longer gearing=better use of turbo.
the rod to stroke ratio on the b18b block is ok, but the bigger displacement more than makes up for it. b18b=1834cc and b18c=1797cc. correct me if i am wrong here.
i would not purchase the b16 bottom end. now if u had the b16 head this would be a whole different story.
hoped i helped somewhat
chris
Co-Founder of AF V-Card Club
1999 Ford Mustang Cobra: Cobra R rims, Magnaflow CB.
"no way man...i saw an LS1 fight godzilla and the LS1 beat godzilla and it looked in the air and was like what do you think of that god and god was like bring it bitch so they fought and the LS1 beat god now the LS1 is god because its the greatest thing ever."
Old 05-29-2003, 12:30 PM
91civicDXdude's Avatar
if you can find the head and block for cheap, i say go for it.
Old 05-29-2003, 02:42 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
i heard a rumor going around over here that a shop sold a kid a b16 bottom end witha ls head, never seen it but heard it from the shops good friend
Team Lonely Drivers
Old 05-29-2003, 07:02 PM
94tegRS's Avatar
94tegRS 94tegRS is offline
put it on a b20 block, then turbo it.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 05-29-2003, 08:47 PM
it would be better to turbo a B18 over a B20 anyday. u cannot boost that much on the B20.
Old 05-30-2003, 09:37 AM
94tegRS's Avatar
why? arent they the same thing besides a larger bore? same r/s ratio.
plus when you get a b20b, its already 8.8:1 so it will take la nice amount of boost.
current
history:
Old 05-30-2003, 06:54 PM
the B20 block will make nice amounts of power, but not an insane amount like the B18. i have seen B20ss make 500 whp and B18's make 900whp. of course both of the engines were fully built and boosting like all heck. the B20 block is similar to the H22 block in the aspect of cylinder thickness. i do believe that u r correct, 94tegrs, the B20 is just a B18 block bored out. (84 vs 81mm i think.) i am not sure on the r/s ratio.
chris
Old 05-30-2003, 09:11 PM
94tegRS's Avatar
so the thin cylinder wasll is the B20's downfall so it cant handle as much boost?, what about getting iron sleeves? with thye same mods and amount of boost wuold the B20 be more powerful though?
current
history:
Old 05-31-2003, 08:25 PM
i am not positive. i just havent seen B20's with any head of ur choice on it making insane amounts of power. i dont know what it is. we need to get someone in here like "gsr" i believe he is one of the most knowledgeable guys in here.
chris
Old 06-01-2003, 08:40 PM
I was just thinking to myself what if i get a b18c1 bottum end or even the b16 if its works and to my advantage. will the head even fit up to my turbo or the piping to the throttle body like it will with a b18b bottum end. will it throw everyone out of wake if i dont get the b18b bottum?
SOLD
V
D16y8-
-Greddy type S BOV
-Tokico Hp shocks
-AEM cam gear
-B&M fuel psi gauge
-Alpine CDA-7893
Old 06-06-2003, 05:24 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
I am not sure bout that question, but there is a guyin jacksonville, Fl with a CR-V B20B in his Civic. He is running a Greddy Turbo kit with intercooler, a Nitrous Express Nter-Cooler system (shoots nitrious onto the intercooler to cool the intake charge and therefor gain HP, about 50-75 hp) and LS (B18B, same engine your head came from) Cams. Apparently the LS cams give the car more power than the CR-V cams, 7 hp on the dyno. Anyways, point is, he runs a12.7 quarter mile @ 109 mph, and thats a fully loaded show car, custom interior, custom bodywork, decah VDC kit for the doors. The enigne puts out 297hp and 312 lb-ft of torque in that set-up. So it is possible to get power and speed for a B20B set-up. The article on this guy and his car is in the June 2003 issue of Honda Tuning. He said the Low compersion made was ideal for the turbo set-up, and the B20B provided more Torque (due to the larger displacement). The B20B, with no turbo, gives you about the same HP as a LS, maybe alittle less without the LS cams in it, but it gives you a little more torque, 133 vs 127. I suppose it is multiplied once you boost it. I still like the LS better, thats what I have a 97 B18B1 LS swap. Both the B18B and B20B give you fairly ow compersion, although the B20B is lower. I know the LS tranny's long gear ratio's are supposed to be good for turbocharging as well.
Old 06-27-2003, 01:11 AM
HCB20Turbo HCB20Turbo is offline
Arrow CRV Turbo...Do you even know?!?
I would like to inform you guys who say that the CRV block is not as stong or a good block for turbo applications; its aprox 1/8" thicker than a H-series motor. Same stoke as an LS and a great block to use. Come find me when my B16/B20 motor is complete. I promise you will learn something. Time, $, correct measurements & the right parts working together makes a fast car. Not what has already been done or been suspected. This post is to inform the first post "member" that the CRV block is just fine, but use a Z10 Block Girdle when building the motor.
Tyler
Life would be boring without boost; Take a look behind you and see....
Old 06-27-2003, 02:20 PM
Would a b18c1 block be n e different than the b18a/b block??? what would be the compression with each using a b18a head and the r/s ratio which is better or would the b20 be a good idea in looking into and I should be able to use my turbo kit i have no on these motors whichever one i choose right?
SOLD
V
D16y8-
-Greddy type S BOV
-Tokico Hp shocks
-AEM cam gear
-B&M fuel psi gauge
-Alpine CDA-7893
Old 07-25-2003, 07:34 PM
elitefreke elitefreke is offline
Talking some info on b series engines...
here is a link for info on most honda motors:
http://www.performancesupply.com/integraswap.htm
hope it helps some on your build.
Silly ricer... your muffler has more displacement than your engine!
