Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 05-20-2011, 09:03 AM
BrianP BrianP is offline
4 Wheel Drive
2003 Yukon XL started it up in the morning and noticed it was in 4 wheel low. Not sure how that happened. Tried to switch to 2 wheel or automatic and the lights on the 4 wheel controls just flash. Any ideas?
Old 05-20-2011, 06:03 PM
jyount jyount is offline
Re: 4 Wheel Drive
Get your codes for the 4 wheel drive system ran. The only bad part is that unless they spent big money on a good scanner, independents can't read these. They are GM specific, usually only the dealer can read em. My bet is either the switch in the dash is bad, or the encoder motor sensor in the transfer case motor one is bad. As a preliminary check the wiring around the tcase. Crappy thing about these 4wd electronics is they are intermittent usually. Might work one day and not the next. Murphy's law though, one of those days will be when you need it...
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
2 wheel drive conversion to 4 wheel drive Parent12 Ranger | Courier 4 12-15-2005 09:17 AM
Rear Wheel Drive Or Front Wheel Drive? Cereal_Killer Avenger 1 06-22-2005 10:00 PM
Changing from Two Wheel Drive to Four Wheel Drive mandymelville-love Bongo Friendee 0 04-07-2004 06:17 AM
all wheel drive or front wheel drive? tran_nsx Integra 7 11-01-2003 09:58 PM
