Old 05-18-2011, 06:23 PM
HDIron883 HDIron883 is offline
2000 Silverado Rough Idle
Please help. I have a 2000 1500 with the 5.3 around 150,000 miles. I would assume that no maintenance has been made to this truck outside the normal oil change.
I was driving it one day and as I was going up a hill the truck seemed to sputter. I thought the transmission was struggling to find the right gear so I changed the fluid. After that it seemed very sluggish. I drove it this way until this recent problem occurred but while searching for this I found out that I may have accidently unplugged the shift solenoids.
One day I walked out and tried to start the truck, it had a rough idle and sputtered until it finally stalled. I can get it to run if I hold the fuel pedal down (around 1500rpm) but once I let off the truck falls to around 500 rpm until it stalls. I pulled the all knowing P0300 code. Random misfire.
Has anyone ever seen this and know to solve it?
I replaced the plugs and still no change.
Old 05-18-2011, 09:43 PM
4x4junkie 4x4junkie is offline
Re: 2000 Silverado Rough Idle
you should check the fuel pressure regulator for correct pressures
4x4Junkie
2012 silverado 1500 ext. cab LT
Z71 4x4 with allstar package
5.3L V8 Flexfuel with 6 speed AT
Onstar / Sirius XM
Factory Tow Package
Electric Brake Controller
Silver Ice Metallic
265/65/18
Wifes Vehicle
2014 Kia Sorento EX AWD
3.3L V6
Toys
2007 Yamaha VStar Silverado
1086cc 45 degree vtwin
Grey and Silver
GPS positioning locator installed
Old 05-18-2011, 09:49 PM
I checked the fuel pressure and it's around 57 psi. I tried to replace the fuel filter but as most of the components on this truck they have a good amount of rust on them.
From my Haynes manual, 57 is in the correct range for this truck.
I kinda think it might be a clogged cat but I can't seem to get the bolts to budge. I know you can check this by observing changes in MAP readings but I can't get the darn thing to idle.
I checked the EGR valve and it seems to be working properly.
Anything else I could check?
Old 05-19-2011, 08:43 AM
j cAT j cAT is offline
THE fuel filter does get rusted badly...get some cloth and rap around the fittings, then with a rust /penitrating oil made for this purpose NOT WD-40 let is soak for a few days then try to remove with 2 with wrenches..
to check the converters ,,,,with the exhaust hot loosen the upsteam O2 sensors....then when the pipes cool down fully remove these sensors leaving the holes open....go for a test drive to see if power returns..if so this is an exhaust restriction...could be muffler or converters or the converters broke up plugging up the muffler /pipes etc....
fuel pressure should be 53-62 psi range and on engine off hold with in a few psi for a few minutes...pressures droping rapidly means pump check valve/fuel regulator/injector[s] or some othe leak...
post back with whats up....
Old 05-19-2011, 12:21 PM
KaIIen KaIIen is offline
When you changed the plugs did you also change the wires? I had this code on a broken wire...
Help with 97 Villager rough idle dscott1838 Villager 12 05-09-2009 09:34 AM
Rough Idle Mayathebee Cougar 1 03-22-2009 08:23 PM
'08 silverado rough idle treemedic Silverado 8 10-17-2008 09:04 AM
95 ck silverado rough idle when cold juniorcarp C/K 3 12-30-2005 01:00 AM
2000 Sierra rough idle when slightly warm jfalbe Sierra 4 04-30-2004 10:45 AM
