Old 05-18-2011, 01:47 PM
jinxedjimmy jinxedjimmy is offline
97 Jimmy stalling when going into park
This is my first post here, and I looked around for similar problems, but could find anything that seemed to match exactly, so sorry if I missed another thread with the same issues. Here it goes...
I have a 1997 4wd 2 door automatic 4.3 v6 GMC Jimmy, that is stalling every time I put it into park. It will also occasionally stall when I am taking a hard turn to the right and slowing down, as in, just as I pull into a parking space. This started last week when the torrential rain started after a long bout of hot weather. The truck has always started a little rough when the weather is wet, or too hot and humid. Now it is starting even rougher. After it stalls it may take a second or two of rest before it will start right back up again. The engine does not sound like it is missing and runs fine as far as I can tell, but I might not be perfect in my observation of it. Also when it stalls, all the lights on the dash do come on, and the check engine light does not stay on, so I don't believe there are any codes.
The rain has been continual for the past week, and I have no garage, so I haven't been able to check any of the connections yet. The transmission was just replaced last year too, with a rebuilt. All the gaskets were replaced on it. The air filter and fuel filters may need replacing though. The only other issue I have really noticed recently is that I think I have a leak in the windsheild wiper fluid line somewhere. I just filled it after being completely dry, and now it is less than half full. I suspect a good portion of it went into the lines because it was dry before hand, but it seems weird for so much of it to be gone. I have heard that Jimmy's sometimes have issues with it leaking and causing problems in other areas of the engine compartment. Still with all the rain, I can't see where, or if it is leaking anywhere.
Any clues, or other diagnostics I can try would be very helpfull. I am not willing to drive it in case it stalls in traffic right now.
Thank you,
AJ
Old 05-18-2011, 03:00 PM
Re: 97 Jimmy stalling when going into park
update...the day was dryer today and the problem seems to have gone away for now. I checked out some of the connections as much as I could and I could not find anything obvious. One thing I did fail to mention was over the winter the car was driving great except for on days it got warm, then as I sat in idle at lights you could every few seconds hear the throttle, and the car would lurch just a bit and the tachometer would jump. I was planning on checking the TPS on it but the problem never persisted so I forgot about it. Once the weather stayed warm it never reoccurred either. The idle speed is computer controlled so maybe it is a connection to the TPS or computer getting wet.
AJ
Old 05-19-2011, 05:13 PM
Please help. I am currently out of work and can't afford too much in garage expenses. Thank you to those that are willing to help me. Yes, I guess I am desperate
Thank you again in advance,
AJ
Old 05-21-2011, 06:51 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
AJ
Any codes or check engine lights?
97 is a bad year for ign switches.
What is your idle RPM in drive or neutral?
MT
Old 05-22-2011, 03:02 AM
No check engine light so I haven't checked for codes. I think my idle RPM was about 500 in drive or park IIRC, but I will check again. I threw in some dry gas thinking it could be water in the tank, and it actually seems to be working much better. We should be getting rain again soon, so I will see if it persists.
Thank you very much for your reply.
AJ
Old 05-22-2011, 06:17 AM
MT-2500's Avatar
AF - Advisor
AJ
Check the idle RPM in drive park and neutrel an with AC on and off and watch for IAC controling idle.
If problem in rain or wet weather check dist cap and rotor and wires for drawing moisture.
If dry ice helped check the fuel filter .
Also clean throttle body butter fly with carb cleaner or TB body cleaner and tooth brush.
Good old TB tooth brushing helps a lot of idle problems.
When was you last good old AC delco parts tune up?
MT
Old 05-23-2011, 06:50 PM
I forgot to test it with the AC on, but I had issues with the AC a long time ago and stopped using it, so never thought about it. I will give that a try next. The idle in Neutral, Park and drive all start out at about 1,000. Sometimes a little higher, but all of them seem to settle down to less than 600, which seems awfully low. Again when I first start driving it it just after a rain it will go below that and stall when stopped at a light. But after driving around a bit at higher speeds it seems to stop doing it. Still it will seem to idle way too low in any gear. The RPM's were also jumping all over the place just after I get it started up after a stall. I wouldn't be surprised if it is a few different issues. It has been a while for a tune up. This was supposed to be a cash for clunkers so I purposely stopped putting money into it. I would rather spend my money on a new(er) car than spend too much on keeping this one running, and sell it for parts if I have too. Still it has been really good for the last couple years after I decided to keep it. I just know the blazers from this year were made to be money pits and sell high priced parts.
Thank you again for your suggestions.
Andy
Old 05-24-2011, 07:02 AM
MT-2500's Avatar
AF - Advisor
Andy
You are welcome and thanks for posting back how it goes.
Yes older blaziers are sometimes expensive to keep repaired.
But with proper testing you can hold down repair expense and have a good running ride.
MT
Old 05-24-2011, 01:08 PM
I have been scouring my manuals to see what the proper idle speeds are. What should my idle speeds be?
Thank you again
AJ
Old 05-24-2011, 06:04 PM
MT-2500's Avatar
AF - Advisor
Thank you again
AJ
With out looking it up it should be 565 RPM or more and should hold withn Ac on or park or drive or neutral if IAC valve is controling it.
Have you checked your under hood sticker?
Have you cleaned the tbi BUTTERFLY?
MT
Old 05-25-2011, 07:14 PM
Okay, I tried it with the AC on and it started surging again. The tach would jump from idle speed to over 1000 every few seconds. It stopped doing it once I turned off the AC. It was the same thing it was doing over the winter on the warm days. I noticed the cover to the AC is cracked in a couple places too.
I have yet to check the TBI butterfly, but hoping to get my tools back from my girlfriends place so I can do it before the weekend, or I will just get it in the shop and get it done while getting the new fuel filter put in.
Thank you very much again.
AJ
Old 05-31-2011, 05:46 PM
Update...Did some inexpensive stuff to try and tune her up. Changing filters, and cleaning the Throttle body which needed it. It has been running pretty good, until I got on the road during a down pour and it started to stall again. Actually it is more of a "turning off" than stalling. All the electrical goes haywire, dash lights turn on and key alarm goes off. Luckily it started back up again almost as soon as it turned off, but it happened several times. I checked to see if maybe I was getting a short in any system and turned off a bunch of electronics in the car including the vent fan. I also noticed that my Cruise Control was on, and turned it off too. I was able to get to a safe place and it has yet to happen again. Rain seems to be the main common denominator. I am not sure how the rain could effect the ignition, but that does seem to be what it is.
Andy
Old 05-31-2011, 06:22 PM
MT-2500's Avatar
AF - Advisor
Andy
Check all grounds and pos feeds and battery cabels.
As said 97 is a bad year on ign switches.
MT
The Following User Says Thank You to MT-2500 For This Useful Post:
jinxedjimmy (06-01-2011)
Old 06-01-2011, 11:46 AM
I have a feeling I am missing something obvious. I checked the battery and connections to it, as well as what what electrical connections I could see. Much of what I see in there does not match the manual. I also found these two "Corrosion Control" boxes located above each wheel well, and one was not connected. I could not find anything about what they are.
Thank you again,
Andy
Old 06-01-2011, 12:10 PM
MT-2500's Avatar
AF - Advisor
Thank you again,
Andy
Did you check them with a volt/ohm meter or just look at them?
MT
Jeep wants to stall when turning into parking space jer2266 Cherokee 1 05-18-2011 02:10 PM
car stalls when shift into reverse when warm 94HeavyChevy Caprice 4 08-11-2008 12:22 PM
stalls when put into park evildragon Alero 3 08-02-2007 08:12 PM
1990 LX going into park sticks when cold dex3703 '88 - '91 Civic | CRX | Wagon | Shuttlee 0 11-29-2005 01:01 PM
Car stalls when shifting into park or reverse too quickly Dave5482 Focus | C Max 2 10-22-2005 08:43 PM
