Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 05-17-2011, 09:56 PM
jyount jyount is offline
Stepper motor in tach?
I have a few questions actually. First, our tach sticks intermittently like the speedo and tachs do on these things. I bought one of the updated style stepper motors off ebay, when it comes I plan to put it in. Have any of you done this?
Going to Florida this summer with a bunch of family members. I am driving the Yukon, I got the interior spiffed up in this thing where it will be a swell ride except, half of the lights are out in the radio, 3 of the 4 steering wheel control button lights are out, and the light on the headlight switch on the side for the fog lights and dimmer are out. ALL of these work A OK, the lights are just out. I am gonna solder the lights in the radio before I go, want to do the same for the steering wheel button lights, and the other too, all the other lights the same lights as the radio? I hate to pull it apart without having new bulbs to replace them... I don't want to replace the switches, the wheel switches are probably 115 or more bucks worth of switches, the headlight switch is who knows how much, and the radio is probably 400 bucks or more, it is a bose, so.... I do not want an aftermarket radio to fix this, that axes the wheel controls, and the oem one is good in this thing. I just want to solder new lights in. I have a low wattage pencil tip solder gun, can desolder and solder, so not worried about doing it really, just need part numbers I guess.
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 05-21-2011, 11:53 AM
Re: Stepper motor in tach?
For anyone who cares, just replaced the tach stepper motor and the fog lights. One of them was missing so I replaced the pair so they matched. The cluster comes out then apart. Gotta Desolder the old stepper and solder in the new one so its not hard, just not a job for someone who doesn't know what they are doing. The hardest part was getting the stupid clips apart of the cluster. The motor was no big deal. Just make sure you turn the stepper motors to zero and put the needles back at zero so they are accurate...
Current job: RN
Wife's
Old 05-21-2011, 12:16 PM
maxwedge maxwedge is offline
A990 racer
Thumbs up Re: Stepper motor in tach?
Thanks for the post back, good info.
Old 05-21-2011, 02:03 PM
Also might note that the motor + shipping was like 7 dollars and some change. To send the cluster off and have it repaired with someone else taking it out and putting it back in it cost around 300 dollars usually so I save something around 295!
Current job: RN
Wife's
Old 05-23-2011, 06:28 AM
wayaboveme wayaboveme is offline
Nice Savings! Appreciate the post. Every little bit of info helps.
Max AC Clicking/Tach Problem tominton Cavalier Problem Diagnosis 1 07-09-2009 03:27 PM
Setting Stepper Motors in Instrument Cluster/Panel bueiz Tahoe 0 05-09-2008 12:48 PM
Stepper motors timmckean 5 Series 0 06-02-2005 07:58 AM
Idle stepper motor rotorfloat Cherokee 2 07-21-2004 08:03 AM
TP stepper Motor (servo) s2125822 General Discussion 0 01-19-2004 05:30 AM
