Old 05-17-2011, 08:00 PM
johnnyw10 johnnyw10 is offline
o/d light flashing stops with door locks
99 windstar when you crank it up and dash lights clearo/d light starts flashing put it in drive and go when auto door locks activate the o/d light goes off trans shifts fine when you put in back in park o/d light starts flashing again and goes back off with door locks?
Old 05-17-2011, 09:46 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: o/d light flashing stops with door locks
Hello and welcome to the forum!
Is the fluid level OK? Sounds like you might be having some problems with the Transmission Range Switch. It sits on top of the transmission you can see it when looking down behind the air filter assembly. You can look up for TSR in the forum, it's a common problem with windstars.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
The Following User Says Thank You to olopezm For This Useful Post:
johnnyw10 (05-17-2011)
Old 05-17-2011, 10:18 PM
Oscar.
would the trs switch have anything to do with shifter being hard to shift from park to drive and back to park? and thanks for the reply
Old 05-17-2011, 10:27 PM
olopezm's Avatar
You're welcome .
Maybe... When I replaced the trs last week on mine the lever became softer than before. Also with the old one, the gear indicator in the instrument cluster wouldn't travel all the way to '1', now it's back to normal...
Another possibility for the hard lever is a set (2) of torx screws under the dashboard, these become loose and the lever feels harder to shift, that would also cause it to wobble depending on how loose they are.
Oscar.
Need help with door locks Hsmith117 Camaro Discussions 6 10-18-2016 09:41 PM
Manual door lock wont stay unlocked! 95 Toyota Camry DerekDougherty10 Camry/Camry Hybrid/Vista 1 05-16-2011 05:13 PM
2002 Buick Regal remote control door lock receiver brytheisen Regal 2 07-20-2010 11:07 AM
Strange problems with door lock chevy71 C/K 1 07-17-2006 03:48 PM
light flash with door lock bcook_84 Thunderbird 1 04-06-2004 12:04 AM
