Go Back   Automotive Forums Car Chat > Ford > Tempo | Topaz
Old 05-16-2011, 10:51 PM
Skip202003's Avatar
Skip202003 Skip202003 is offline
coolant pressure
I have a 93 tempo. Replaced thermostat recently, and a leaking heater hose 2 days ago. there is no flow to or from the reservoir, and when the car is driven, the temp gauge goes down to cold or below, but when it sits and idles it appears to work OK. Also I get plenty of heat from the heater in the car. My question is what is the pressure supposed to be at operating temp?
Old 05-17-2011, 07:37 AM
danielsatur danielsatur is offline
Re: coolant pressure
The boiling point of water is 212f, coolant and a pressurized cap will help
increase the boiling point.
The thermostat opens 180-195f, and a cap opens around 7 lbs.
A coolant testor will show how much protection befor boil over.
It might be time for a new radiator cap too!
The Following User Says Thank You to danielsatur For This Useful Post:
Skip202003 (05-17-2011)
Old 05-17-2011, 03:51 PM
Skip202003's Avatar
Thanks. My cap is rated for 16 lbs. I think I'll replace it. What reason would there be for installing a higher pressure cap?
Old 05-18-2011, 08:04 AM
To increase the boil point, and loss of coolant.
Consider using a Prestone flush kit , using water pressure to force out air lock!
Back flush heat core, clean bugs, and leaves in front of of Air cond condenser core +
Radiator.
Note - Make sure fans are turning on at proper temp.
Help - 1.5 L Coolant problem IHMIRAGES Mirage 8 03-10-2011 06:05 PM
Brown sludgy coolant (oil in coolant?) wagslick Malibu 3 01-03-2010 08:29 PM
taurus coolant pressure cap keeps getting loose blkmonday Taurus | Taurus Wagon 4 06-11-2007 07:51 PM
Coolant pressure Artley 6 Series 2 10-27-2003 03:38 AM
Coolant pressure F1973 Engineering/ Technical 1 05-06-2003 10:57 AM
