Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 05-14-2011, 06:22 PM
copdills copdills is offline
2001 Malibu pass power window problem
2001 passenger door power window is down and won't go back up and I am lost the switch on the driver door or the passenger door will not work the window up or down all the other windows work , I took the door panel off and the window is locked down solid and you can't pull it up (I tried) should I take the motor off and see if I can raise the window maybe due to the motor being lock up ,the motor does not make any noise at all when you use the window switches ,any suggestion will be appricated
Thank you Randy Dills
Old 05-14-2011, 06:35 PM
dondeere dondeere is offline
Re: 2001 Malibu pass power window problem
Randy, try to unplug the motor and put 12 volts to it. Reverse the polarity to make it change direction. If that fails your motor is toast. A cheep volt meter is also a good tool.
Old 05-15-2011, 03:30 AM
Thank you Sir I will try that, Thanks again
'95 Passat FL power window problem frescoraja '93 - '96 1 06-19-2010 01:44 PM
`99 Power Window Problem.. beadlingi Prism 0 04-27-2009 06:13 PM
2001 Sebring LXI Power Window Problems katokissa Sebring | Sebring Coupe | Convertible 0 07-22-2006 10:23 AM
94 TransSport Pass. Power window problem senna95 Trans Sport 0 09-12-2005 03:39 PM
2001 Sentra GXE power windows problem EG_Civic Sentra | 200SX (USDM FWD) 2 12-28-2004 12:11 PM
