Old 05-13-2011, 09:56 PM
binckley binckley is offline
95 s10 blazer dome light problem
MY blazer's problem started out with the dome light staying on some times. It was a intermittent problen then got worse, It started blowing the fuse for the dome!(horn,tailgate latch) are on the same circuit,any ideas would be helpful! thanks
Old 05-14-2011, 01:46 PM
4x4 blazerguy 4x4 blazerguy is offline
Re: 95 s10 blazer dome light problem
I don't have an answer to your problem. What I know is somewhere you have a SHORT. Just start checking wires start from the source or go backwards starting at the horn. In my mind the most likely is in the steering column ie: horn. Disconnect it & see if the problem is solved. Disconnect it before the column.
Do that with the other items until you find the problem circuit then start tracing.
94 s10 blazer 4wd 4dr 4.3 parting out chevyshitsonford Classifieds 9 10-27-2016 09:35 PM
94 s10 blazer 4.3 high oil pressure chevyshitsonford Problem Diagnosis 4 03-08-2009 09:11 AM
2000 blazer dome light question heatwave202 Problem Diagnosis 3 05-06-2008 04:15 PM
'99 Blazer dome light on intermittently NINFan Problem Diagnosis 3 10-15-2007 08:09 PM
93 Blazer dome lights won't go off cammerkit Blazer 3 01-27-2005 10:46 PM
