Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 05-13-2011, 03:47 PM
jimbo3san jimbo3san is offline
OE Brake Pad Materials - 1998 Camry V6 XLE
I've searched these posts to see if any one knows definitively what the brake pad material is comprised of on the Camry (4th Gen V6). I have the same question for the 4R...but that is a different sub-forum.
Anyway, I am wondering if they are semi-metallic or organic...ceramic perhaps?
I have spoken with a close acquaintance who is a Toyota mechanic at a local dealership and wasn't sure the composition of the material. He said that the materials used in the aftermarket pads are essentially the same. I was somewhat surprised that he went this way given that he is normally *very* adamant when it comes to OEM parts.
He did mention that after-market ceramic pads wear the rotors heavy and to avoid them for that reason.
Thanks,
Old 05-13-2011, 04:37 PM
Scrapper Scrapper is offline
AF Premium User
Re: OE Brake Pad Materials - 1998 Camry V6 XLE
Thanks,
i say o-e's if you plan on keeping it awhile semi-metalic and o.e's on your rotors or better not cheap ones. another thing did you go to autzone.com and look at the pads and rotors not the cheap ones?
Old 05-13-2011, 07:35 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
The OEM pads are semi-metallic.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 05-13-2011, 11:49 PM
Brian R. ,
Thank you for the info!
I am going to post a similar question in the 4R forum. But do you know if it is the same material for the 4R as well ('99 Limited)? Toyota's website talks about about specific "...friction materials matching the dynamics of the braking system..." I'll probably end up getting OE pads/shoes for both the Camry and my 4R but I wanted to see what the materials were that performed so well in both of these cars.
The Camry had about 115K on it when I replaced the original factory pads in 2005. The current pads (For some reason I went with a ceramic then) have about 60K on them and they are ready to be replaced.
My 4R, believe it or not, has 135K on the factory pads and rotors but they are getting close to needing replacement.
I am likely going OE, simply based on posts here and my own experience. (2X the life, no noise, very little dust, and low rotor wear! Amen.).
Thanks,
Old 05-14-2011, 09:47 AM
Brian R.'s Avatar
Resident Chemist
I got similar life from mine. I changed them at 120 k. I was getting some shudder (4runner).
Same lining material.
1998 Camry XLE Signals and Door Locks Clicking CamryGuy Camry/Camry Hybrid/Vista 9 08-30-2005 11:27 AM
1998 Camry XLE scott9 Camry/Camry Hybrid/Vista 4 03-26-2005 11:06 AM
Maintenance Shedule 1998 Camry XLE CamryGuy Camry/Camry Hybrid/Vista 1 10-07-2004 08:18 AM
