Old 05-10-2011, 01:25 PM
s k anderson s k anderson is offline
96 Silverado A C Control head unit ?
I had a problem w/ stereo ,worked on it and re installed unit.
When i put it all back I must have did something cause now all my AIR blows to floor.
Any thoughts before I take it apart again would be great.
Old 06-07-2011, 05:42 PM
autotech234 autotech234 is offline
Re: 96 Silverado A C Control head unit ?
that is controlled by engine vacuum. Vac line gos from top of engine manifold throw the passenger side fire wall to control head. make shue you have no leaks in that vac supply hose. That can cause you problem
Old 06-09-2011, 09:41 AM
Thanks, i fixed it,the actuator located to right and above gas pedal had gotten knocked off center. Works great after re bolting it back in place.
Another issue for the life of that truck each time you take a corner over uneven ground where rear end flexs there is a popping noise under rear.
Sounds like the axle shifting .any thoughts.
Head unit install = broken speedometer? robkule422 Car Audio 2 01-03-2011 04:29 AM
07 Chevy Silverado aftermarket head unit security question matrx10503 Car Audio 2 02-05-2010 05:58 PM
1999 Intrigue Climate Control Head Unit Hunter2049 Parts for Sale 0 09-25-2007 09:06 AM
climate control head unit question mike561 Grand Prix 13 06-22-2006 04:02 PM
2003 Silverado JVC head unit install - OK carmelfrapinator C/K 0 11-28-2003 07:07 PM
