Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 05-10-2011, 01:13 AM
ice2626 ice2626 is offline
Cruise Control on 02' LS
-02' Lincoln LS
-V8
-Crusie Control Malfunctioning
When I replaced my faulty clockspring, I thought it would fix my cruise control problem along with the rest of my clockspring issues. Unfortunately, it did not.
My cruise will engage sometimes. However, it only works for a quarter of a mile, or maybe 2 miles, than it shuts off and will not re-engaged.
After reading a few post on here, I assume its a "servo motor". Can anyone eleborate on what exactly this is, where it is located, and/or how to test this part to verify it is indeed the culprit? I also seen in one post the mention of a sensor behind the brake booster, is this a legit possiblity?
Old 05-10-2011, 06:38 AM
shorod's Avatar
shorod shorod is online now
SHO No Mo
Re: Cruise Control on 02' LS
When the cruise stops working does the green indicator on the instrument cluster remain on?
-Rod
Old 05-10-2011, 10:12 AM
-Rod
NO, it goes off.
Old 09-02-2011, 02:03 AM
jsg417 jsg417 is offline
I have a problem with my cruise as well on a 2002 I just purchased. The light on the dash comes on as if the cruise were engaged but as soon as I lift off the pedal the car just drifts down so the cruise is obviously not working.
Any suggestions?
Oh, I forgot to mention mine is a V6
Old 09-02-2011, 06:35 AM
shorod's Avatar
SHO No Mo
I'd start by checking the linkage from the servo to the throttle body to make it is in good shape.
-Rod
Old 09-02-2011, 09:53 AM
Thanks, I'll start there.
BTW I posted in the thread about the AC blowing hot on one side and cool on the other. I have this problem intermittently as well. I ran both self-diagnostics that were suggested and each time recieved no codes, just the entire display lit up.
Could this indicate that the system might just need recharged?
Old 09-02-2011, 10:03 AM
joegr joegr is offline
Classic failing DCCV symptom.
08 Grand Caravan cruise control Dick McDonough Caravan | Voyager 0 03-09-2010 11:17 AM
horn/cruise control uspres2020 Escort 10 02-17-2010 05:06 PM
94 Ram no cruise controll mrkabokieman Ram Pickup | Ram SRT10 3 08-16-2009 03:36 PM
Cruise control freak out cobraprince 3000GT/Stealth 13 03-23-2009 10:41 AM
1998 Zx2 Cruise Control Problems ddppci ZX2 1 02-17-2009 10:59 AM
