Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-09-2011, 03:17 PM
badger6 badger6 is offline
Whining when first started.....
98 Rodeo, 3.2, 2wd, 135 K. I have noticed a light tapping or clicking upon starting which seems to go away after about 30 secs to a minute. That has been going on for a couple years, so it seems normal to some extent on these things. The last couple mornings I have noticed a whining sound that goes up and down with the RPM, kinda like the whir of a weed eater string. The whining seems to go away after a minute or two. I been reading on here and I think it may be the idler pulley (top left above the belt tensioner). A couple hours later after it cooled, I pulled the belt off and the pulley turns but it sort of squeaks. I put the belt back on and started it up and the whine was not there, but the pulley (I think it was the pulley) was going squeak, squeak, squeak, like an old unbalanced washer or dryer. I read in the FAQ that the pulley usually squeaks when it's below freezing. Does the outside temp really matter, because it hasn't been cold here in a while. On a side note, I don't think the water pump, timing belt, or belt tensor have been replaced on this vehicle. Opinions ???
Old 05-14-2011, 10:00 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: Whining when first started.....
When a pulley gets bad enough temp isn't going to matter.
And at 135K, you really should replace that timing belt real soon.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Whining Noise When First Started KGaugh1805 TrailBlazer | Trailblazer EXT 1 10-02-2007 09:32 AM
impreza 94 when first starts -bearly runs, but when warms up its just fine terenty Impreza/9-2x/Outback Sport 0 08-22-2006 01:20 AM
whining when engine starts denalae Accord/TSX/Accord Hybrid 5 09-28-2004 12:10 PM
Motor stumbles badly when first started Railroader Caravan | Voyager 10 05-14-2004 01:53 PM
car stalls out when first started CRXsk8er Mustang Talk 1 08-31-2003 05:03 PM
